low oil pressure/ fuel pump shut off
I recently purchased a 1996 Civic LX and I need some help. I'm not overly familiar with the car as of yet but I need to know does the car have an automatic fuel pump shut off when the oil pressure is to low or is this just an aftermarket add on? It is equipped with the SOHC engine with
and an electric fuel pump. Any help would be much appreciated.
and an electric fuel pump. Any help would be much appreciated. If you think a good mechanic is expensive, try hiring a bad one
Re: low oil pressure/ fuel pump shut off
Still no.
The oil pressure switch is ONLY connected to the oil warning (gravy boat) light.
It is not connected in any way to the fuel pump or fuel injection system.
You can drive around with the oil pressure light glowing bright all the way up until the time the engine hatches.
Still no.
I know the old GM Vaga had one. About 30K when the cylinder scrapings packed the oil pick up , you could get 5-10k more engine life out of them by jumping out the switch.
The pump (main relay) is shut off shortly after the engine comes to a halt and ignition pulses are no longer seen by the computer, you can check this out for yourself to be sure
CarStuff
Dec 6, 2020 12:52 PM
Jonnie.
Jan 13, 2019 11:21 AM
TiNkErBeLL
Jan 24, 2002 12:40 AM
