dumb clutch & rev limit questions
Hey, I have a couple of questions that i'm sure you guys can answer:
Where does the rev limiter kick in on the '02 EX? At red line, or after?
If your screwin around and hit the rev limiter while in neutral, is it worse than if you hit it while in gear? (being that there's no load on the engine in neutral..)
If you dump the clutch @ 4-5k rpm on a gravel road, does it do any less clutch wear and/or drivetrain stress than if you do it on pavement?
thanks.. i told ya they were dumb
I beleive the rev limiter is at 7K RPMS, i've hit mine once
As far as hitting the rev Limiter in gear, or in neutral, it could go 2 ways
1: Hitting it in neutral means that the RPMS are gaining quicker, so it could potentially rev a little past the Rev limiter, which could cause damage
2: Hitting it in gear means the engine has momentum behind it preventing it from backing off the rev's as fast, meaning it's at a higher rev for longer, but not as high as hitting it in neutral.
For which one does more damage, I'd think that it's probably about the same, though you really have to screw up to hit the rev limiter while your in gear. Now if your going downhill and you hit the revlimiter in gear, that could F-up your car provided the slope was steep enough.
If you dump the clutch on gravel, the wear will be less, if the wheels start spinning at the same speed as the engine, keep in mind the clutch can only wear when it's not traveling the same speed as the flywheel.
I hope that helps
I hope that helps
Originally posted by NeonImpact
well malice, there are your answers....
but my question is....
1)WHY?!?!
2)WHY?!?!
3)WHY?!?! Gravel Road?!?!
1)WHY?!?!
2)WHY?!?!
lol.. i was just curious
..and no I wasn't dumping the clutch at 4-5k, but I was thinkin about it.. haha.. there's a certain gravel driveway i'd like to tear up a bit.. :devil:
Autocross Junky
the rev limiter dosn't kick in till about 7100-7200 rpms. How do I konw this, I autcross! you can do a lot of interestign things with your car in second gear.
yeah i wouldnt spin out on gravel, it can **** up a whole lot of stuff on your own car. i once accidentaly drove from a paved road into a gravel road with about 35mph, that **** sucked, stones were flying everywhere... i was worried i ****ing blew my tires or so... it has happend to me before....
anyways. do what we cant stop ya from
Wraithen
Jun 7, 2015 01:48 PM
