Frost in car
Old Jan 31, 2003
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
Frost in car
i dunno if anyone else has this problem but if i leave my car outside for a few hours i get frost on my windows.....not just a little a lot and on every window
And yes my windows and doors are closed
I do live in Michigan and as you know it does get pretty cold but i should i be getting frost???
Old Jan 31, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
do u get frost inside your car or on the outside? i am confused. its normal on the outside
INJEN
Old Jan 31, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Outside is normal... if it fogs up when you get back in... its because you are breathing on the windows and it's fogging them up... if theres actually crystals on the inside of the windows... I dunno. I've never heard that, but there would have to be some water in the air in the car to cause that. Try running the A/C so the dehumidifier kicks some of the moisture out.
Old Jan 31, 2003
myhonmyhonda's Avatar
myhonmyhonda is an unknown quantity at this point
I live up in Michigan next to Port Huron. I've never gotten anything like what you've described.
Old Jan 31, 2003
the frost is on the inside....but im going to try running the A/C
thanks
Boilermaker1
Old Jan 31, 2003
Falcon's Avatar
Falcon is an unknown quantity at this point
i had that happen to me last night
its just cause i was in the car for about 10 minutes with just the heat on (not the A/C)... then got out
we have nice subzero temps here in london (prolly about as far north as you are if you're in detroit) so the moisture from my breath or whatever just froze up on the windows
it wasnt that bad tho.. just a little around the edges
Old Jan 31, 2003
injencivic's Avatar
our cars use the a/c automatically when you use defrost.
INJEN
Old Jan 31, 2003
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
Quote
[hr]Originally posted by: injencivic
INJEN[hr]
That's true but you can make it so it doesnt come on when you hvae the defrost on. I did it. I's like...hold the ac button and defrost button down....turn your car off....restart car....then let go of buttons or something like that. I dont know any more. That was my very first mod
As far as the frost goes. I had that very same problem in my 93'Vic. Let me ask you 2 questions. Did you 1 either have it on the recirculating air/not taken from outside mode or 2 have alot of people in your vehicle before your last trip. Both things cause the same problem. Moisture inside the vehicle. Many people is obvious because they all breath and give off moisture, but the 1st one is where i made my mistake.
I thought the air was a little warmer on the recirculating function but i didnt think about the fact that it also recirculates the moisture that you give off in your breath. Later that day after work. I scraped off my outside windows and the frost on the inside was so bad that i couldnt see AT ALL. Since that was the first time i tried the recirculating option i put 2 and 2 together and got 73. and there you have it.
Hope that helps
Injen [IMG]i/expressions/laugh2.gif[/IMG]
Old Jan 31, 2003
ohiojosh78's Avatar
Ahh i found the link to the TURN OFF YOUR A/C It's by OPGForce about 4 or 5 down
Old Jan 31, 2003
ohiojosh78 i think your right.....it probably was because of the amount of people that i had in the car....i drive 3-4 people home from school everyday so im pretty sure thats the reason
thanks for clearing that up
Old Feb 1, 2003
ohiojosh78's Avatar
Glad to help.
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
ImmortalEX
Oct 31, 2001 10:00 PM
