FYI: Model Gear Ratios
Subscribe
Jan 23, 2003
EX 5M Gear Ratio
First 3.143
Second 1.870
Third 1.241
Fourth 0.970
Fifth 0.757
Reverse 3.231
Final Drive Axle Ratio 4.412
EX AUTO Gear Ratio
First 2.722
Second 1.469
Third 0.975
Fourth 0.674
Reverse 1.955
Final Drive Axle Ratio (:1) 4.067
HX 5M Gear Ratio
First 3.461
Second 1.750
Third 1.096
Fourth 0.857
Fifth 0.710
Reverse 3.231
Final Drive Axle Ratio 3.208
DX/LX 5M Gear Ratio
First 3.462
Second 1.870
Third 1.241
Fourth 0.970
Fifth 0.711
Reverse 3.231
Final Drive Axle Ratio 4.111
DX/LX AUTO Gear Ratio
First 2.722
Second 1.469
Third 0.975
Fourth 0.674
Reverse 1.955
Final Drive Axle Ratio 4.067
edit: astr033 points out HX CVT final drive ratio = 5.81
Reply 0
Jan 24, 2003
Quote:
Quote
[hr]Originally posted by: PESTLNC
EX 5M Gear Ratio
First 3.143
Second 1.870
Third 1.241
Fourth 0.970
Fifth 0.757
Reverse 3.231
EX AUTO Gear Ratio
First 2.722
Second 1.469
Third 0.975
Fourth 0.674
Reverse 1.955
HX 5M Gear Ratio
First 3.461
Second 1.750
Third 1.096
Fourth 0.857
Fifth 0.710
Reverse 3.231
DX/LX 5M Gear Ratio
First 3.462
Second 1.870
Third 1.241
Fourth 0.970
Fifth 0.711
Reverse 3.231
First 2.722
Second 1.469
Third 0.975
Fourth 0.674
Reverse 1.955
Final Drive Axle Ratio 4.067[hr]
Thank you for this info, its always nice to be able to come on this site and find the really usful things on here
Reply 0
Jan 24, 2003
you know of any place where i can find this info for like a porsche gt2 or like a ferrari? or any other car thats got more than 450HP and a 6 speed tranny?? lol
im serious....
i need to set up gear ratios for a drag 6 speed thats pushing 476HP and a 100 shot....what im looking for is really quick acceleration, and so that it doesnt skid at the launch...so not a lot of torque at the start...is that possible?
ive kinda been playing around w/ it a bit...but its not perfect. this is the current setup:
1st: 5.604
2nd: 3.723
3rd: 2.751
4th: 2.07
5th: 1.557
6th: 1.254
final: 2.711
please help me if you know where i can find this info.
Reply 0
Jan 24, 2003
Good info thanks. This explains why the EX 5spd revs higher since its final ratio is 4.4:1 and why the HX gets good gas mileage with a more highway type gearing of 3.2:1.
Reply 0
Jan 24, 2003
This website http://www.new-cars.com/2002/honda/h...fications.html gives different numbers for some of the HX manual gear ratios. All the other numbers look the same for the other trim levels. What's your source? By the way, you left out the HX CVT. [IMG]i/expressions/face-icon-small-frown.gif[/IMG] The final drive ratio for the HX CVT is 5.81.
EDIT: had to fix a typo
Reply 0
Jan 24, 2003
Quote:
Quote
[hr]Originally posted by: astr033
EDIT: had to fix a typo[hr]
Whoops, I didn't forget it, but automatically thought "infinite gears" so I omitted it.
Reply 0
Jan 24, 2003
Quote:
Quote
[hr]Originally posted by: PbFoot
im serious....
1st: 5.604
2nd: 3.723
3rd: 2.751
4th: 2.07
5th: 1.557
6th: 1.254
final: 2.711
please help me if you know where i can find this info.[hr]
RSX Type S has the 6 speed manual tranny
Reply 0
Jan 24, 2003
So do alot of cars...try putting an RSX ratio tranny into a 450hp car.
He's looking for gear ratios to match his projected output.
Reply 0
Jan 26, 2003
Oh yeah, if you add on a turbo then you may want to get a final drive gear set for D series engines. You'll have more power with the turbo throughout the whole rpm range (if the turbo is properly sized to our car), so you don't need to rev the engine as high to accelerate as fast as you need to. To maximize your top speed you can increase the final drive ratio. You'll sacrifice some low end torque, but the torque that you do have in the higher rpm's can be used more effectively to speed up the car. At least I think that's how it works.
Anyway, this site: A&J Racing Online has the 4.714 and 4.929 available for our cars. Let's say that the maximum speed of the car is something like 140mph (for an EX let's say). Let's say that this is in 5th gear and at redline. Now, if you get the 4.929 final drive gear you could go 154mph. With an LX the difference is even more pronounced since the final drive gear is a little smaller.
Anyway, if you're building a race track civic then this may be something to consider. [IMG]i/expressions/beer_yum.gif[/IMG]
Reply 0
Jan 27, 2003
Quote:
Quote
[hr]Originally posted by: Grey
Anyway, if you're building a race track civic then this may be something to consider. [IMG]i/expressions/beer_yum.gif[/IMG][hr]
That's totally backwards. Going to a higher number decreases the speed for a given RPM, not increses it. So instead of topping out at 140, you might top out at 132. But you'd get to 132 quicker than the guy with the same engine gets to 140....
Reply 0
Jan 27, 2003
Are you sure? I thought that I understood it after reading this: Frequently Asked Questions About Differentials
Quote:
Quote
[hr]With a lower gear ratio the drive shaft (and thus the engine) turns more for each revolution of the wheel, delivering more power and torque to the wheel for any given speed.[hr]
Oh, never mind. That's where I went wrong. The sentence above it states...
Quote:
Quote
[hr]The higher the number, the lower the ratio: a 5.29 gear has a lower ratio than a 4.10 gear.[hr]
I thought that the lower the number, the lower the ratio. Nevermind, my bad. So yeah, strike that and reverse it. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Edit: Nice, I did some calculations and it seems that it would be possible for us to score a 15.2s @ 89mph with the 4.929 final drive gear. I wonder how much this thing costs? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Reply 0
Jan 27, 2003
I'm still not sure I get all this. I understand now about the higher the number the lower the gear ratio, which means the engine turns a lot more for each rotation of the wheels, which I presume means quicker acceleration. If that's all true, then theoretically I should be running 15s with my 5.81 ratio? Obviously I don't really know what I'm talking about. I'm just looking for a clear explanation on what these numbers are telling us.
By the way, I know there is info on the final ratio for the HX CVT but I wonder what the high gear ratio is for my car. Anyone know?
Reply 0
Jan 27, 2003
I think I just found my answer at http://www.caranddriver.com/xp/Caran...est_audia4.xml
According to this article, the HX CVT the gear ratios span from 2.47:1 to 0.45:1. Another interesting thing I got from the article: "Ultra-low gearing negates the need for a power-sapping torque converter." Maybe that's why the final drive ratio is 5.81?
Reply 0
Jan 27, 2003
Quote:
Quote
[hr]Originally posted by: Neonmike
Quote:
Quote
That's totally backwards. Going to a higher number decreases the speed for a given RPM, not increses it. So instead of topping out at 140, you might top out at 132. But you'd get to 132 quicker than the guy with the same engine gets to 140....[hr]
In theory, yes. However, there is a practical limit. You can't design a transmission with 7 or 8 gears, because the time it takes to shift those extra gears usually negates the advantage you gain by making the lower gears shorter.
Reply 0
Jan 27, 2003
Quote:
Quote
Nice, I did some calculations and it seems that it would be possible for us to score a 15.2s @ 89mph with the 4.929 final drive gear. I wonder how much this thing costs? [IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
hey grey, thanks...ill check that out when i get home. after playing with the gears a bit ive been able to set the ratios so that im getting the results i want. i dont remember them off the top of my head right now, but ill post them when i get home (theyre written down).
as far as numbers go...ive been consistent w/ 9.7's at about 138-139mph for the 1/4 mile. i think thats not too bad. hehehe
Reply 0
Jan 27, 2003
Huh!? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
What are you driving? [IMG]i/expressions/laugh2.gif[/IMG]
Reply 0
Jan 27, 2003
6th Gen Si (hatch)...
modded to ****...LOL...i cant even list it all. hahahaha...but im dynoed at 522hp @ 8k RPM. [IMG]i/expressions/demon.gif[/IMG][IMG]i/expressions/demon.gif[/IMG]
i still cant find the gear ratio numbers...but ill post them as soon as i can. maybe with a list of mods too...tee hee
Reply 0
Jan 27, 2003
Dayam! Naturally Aspirated, Forced Induction, or Nitro Injection?
Reply 0
Jan 28, 2003
vortech supercharger, high boost pulleys, lots of internal motor work...LOTS of other stuff....ill try to post details when im home...had trouble getting online last night.
Edit:ok...heres the mods:
high flow fuel pump, and high flow injectors
bore and stroke
cam gears and cam shaft
P/P
throttle body
and low compression pistons
vortech supercharger w/ high boost pulleys
centerforce DFX flywheel and clutch
tunable gear box
electromotive TEC3 engine management system, nology spark plugs and wires
I/H/W w/ high-flow cat
Nitto 555R drag radials
and my gear ratios are:
1st: 5.916
2nd: 4.011
3rd: 2.733
4th: 2.036
5th: 1.552
6th: 1.294
final: 2.724
any suggestions?
Reply 0
Jan 28, 2003
Sounds hella k3wl. Suggestions on what? The gear ratio's? I have no clue...
Reply 0
Jan 28, 2003
Very sick numbers there. Pretty quick civ huh?
Reply 0
Jan 30, 2003
yeah...its a damn quick civic. lol
Reply 0
Subscribe
