16's and Wilwood Big brakes
Old Oct 8, 2002
HondaLuver's Avatar
Its a celebration bitches!
well i know this goes in Tire, wheels, and brakes category. but i thought this would be a better place to talk about it... i want to know if this set up should work...
16 inch rota slipstreems and Wilwood Big brakes which are larger 12.19" diameter disc ...
will this setup fit? or should i get 17's...
here is a chart... that i found... maby it could help
[wheel size] maximum disc size
13" 240mm
14" 260mm
15" 278mm
16" 308mm
17" 325mm
18" 355mm
Old Oct 8, 2002
CivicTypeR01's Avatar
CivicTypeR01 is an unknown quantity at this point
HondaLuver now is the offset chart for the slip streams? if it is and you do the metric to standard conversion you come out having 12.19 inches to equal just over 309mm. This means that if you have the correct chart here than you are going to have to go to the next size up. You should at least allow around a 1/2" - 1/4" of area inside the wheel also for cooling. Hope this helps you out.
Peace...
hondadriver95
Jul 13, 2015 09:43 PM
OptimisticWay
Jul 10, 2015 04:31 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
General 7th Gen
Jul 9, 2015 10:17 PM
Causemo
Jul 5, 2015 06:42 AM
