rolling fenders
Old Sep 29, 2002
phlipsidez's Avatar
phlipsidez is an unknown quantity at this point
rolling fenders
I really need to roll my rear fenders cause i'm getting a lot of rubbing on my passenger side. (lowered on neuspeeds with 215/45/17) i dunno why it's only on the passenger side, i guess i have a little of an uneven drop.....??? anyway, my question is how much is it to get fenders rolled? one shop said $60 per fender. this about right? also, does it take long to do this? i shouldn't have to leave my car there right? .... thanks....
Old Sep 29, 2002
nytejade's Avatar
nytejade is an unknown quantity at this point
If you haven't gotten an alignment since you dropped your car, do that and it may fix it. Mine used to rub, but it doesn't anymore since I got the alignment. I'm on 215/40/18. I can't have people in the backseat though or it rubs like crazy.
Old Sep 29, 2002
phlipsidez's Avatar
yeah, it mainly rubs when people are in the back seat... sometimes when they're not...and yeah, i've had these springs for like several months now, and i have already had an alignment.
Old Sep 29, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
you could probably take a dremel tool and saw off the fender.. you'd have to coat it with something to prevent rust though.
Old Sep 29, 2002
phlipsidez's Avatar
i'm not brave enough to do that
Old Sep 29, 2002
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
Just take a baseball bat and put it up against the fender and roll it along applying decent pressure. That will do it good. Just if you use an allum. bat put like a tee-shirt outside of it so it dosent crack the paint. Good luck
~nick~
Old Sep 29, 2002
phlipsidez's Avatar
can someone give me a real answer to my question instead of these smart *** pw answers? thank you.
Old Sep 29, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
well, to be honest...
MAGIC gave you the best answer here so far, up until this one. the way most autobody shops actually roll fenders is with a wooden baseball bat, or a wooden rod. you firmly roll it back and forth along the inside of the fender. i only recommend doing this on the rear.
and for the other IGNORANT people who posted up on this thread, getting an alignment kit on the rear will only make the rubbin worse, as it will bring the top part of the wheels outward, causing them to be closer to the actual fenders. im actually surprised that your even having this problem with 17" rims, however this maybe caused by using a wider tire than the standard 205s...
anyways, if your a little worried about doin the ROLLIN yourself, id highly recommend going to a body shop and having them do it. shouldnt be anymore than $100 for both rear fenders.
g'luck!
Old Sep 29, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
Just take it to a body shop or one of the big tire dealers: Discount Tire, NTB, etc... Some of these will have the tool needed: It looks sorta like a crank, with its base resting on the tire, and the rollers against the inner fender lip, they can just roll it from side to side and with increasing pressure. This works perfectly and does not cause any paint cracking or scratching. I had that done on my old Jetta Vr6...I then put some 17x8.5 rims on that ****[IMG]i/expressions/demon.gif[/IMG]
EDIT: Forgot about pricing...the four fenders ran me about $80 in NYC.
Old Sep 29, 2002
tok's Avatar
tok
tok is an unknown quantity at this point
any competent bodyshop should be able to roll your fenders for less than $150
this is the tool most of them use
Old Sep 29, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
Getting an alignment will most likely fix the rubbing problem. I had a rubbing problem with one of my wheels, so I had a shop change the negative camber to about -1.3 degrees and adjust the overall toe so that it wouldn't have uneven tire wear. The problem was fixed instantly.
Alternately, you can just use a baseball bat to roll your fenders yourself. But this might not solve the rubbing problem entirely.
Old Sep 29, 2002
nytejade's Avatar
Quote
[hr]Originally posted by: BLUENVY01
g'luck![hr]
You're calling me ignorant? I'm speaking from personal experience. I put shorter springs in the rear of my car and the passanger side kept rubbing because the negative camber was too high. It was rubbing on the sidewall and literally chewing it apart. After getting an alignment ( and not an alignment kit, you idiot. wtf is an alignment kit? ) my tires didn't rub anymore. Sometimes the rub against the TOP of the tire because the camber was adjusted properly, but it doesn't cause any damage.
Learn how to spell, and know what the hell you're talking about before you start calling people ignorant. ok?
Have a nice day.
Old Sep 29, 2002
nytejade's Avatar
Quote
[hr]Originally posted by: tok
[hr]
Before you go around assuming every body shop has this tool you should know it costs about $1,500 and most body shops won't have it. They will however find another means.
Tedverseti
Sep 29, 2015 05:41 PM
General DIY
Sep 25, 2015 08:02 PM
meicalnissyen
Sep 25, 2015 12:12 AM
emiixo
Exterior
Sep 22, 2015 03:53 AM
rnaodm
Sep 21, 2015 12:42 PM
