NITROUS vs TURBO
DIY King
Quote
[hr]Originally posted by: SuperNegro
that water doesnt stay cold forver you have replace it[hr]
Quote
and being stopped has nothing to do with performance of your turbo, your not boosting so it doesnt matter long as you are moving and getting air flow over your intercooler you have no problem, the problem is when people go out and buy a GTR intercooler core for a T25 turbo or buy a starion intercooler for a T3/T04E if you have a street car all you need a properly sized Air to Air intercooler.[hr]
Turbocharger
Intake pipe
Turbo to piping hose
Throttle body to pipe
Hose clamps/Connectors
Hose clamps/Air filter
Ducting/Air filter
Connector/Air filter
Air filter
Boost gauge
Turbo & Drain gaskets
Wastegate
Steel downpipe
Header
Header/Turbo bolts
Downpipe/Turbo bolts
Wastegate/Flange bolts
Discharge tube
Turbo oil drain flange
BlowOff Valve
Fuel Pressure regulator
Brass T oil sending unit
Oil Sending Nipple
Steel oil line
Turbo oil inlet
Steel oil return line
Oil return to pan
Instruction sheet
Thermal wrap
Plastic vacuum fitting
Vacuum hose
Vacuum T fitting
this is the same kit you offer at $3000.00...i will call when i am ready to order...i have your number, only one problem i see...the fuel pressure regulator...if i am assuming right the bigger injectors will take the place of this on our cars....thats all i have to say just easier to talk on this forum than the phone...
Intake pipe
Ducting/Air filter
Air filter
Boost gauge
Wastegate
Steel downpipe
Header
Header/Turbo bolts
Discharge tube
BlowOff Valve
Oil Sending Nipple
Steel oil line
Turbo oil inlet
Oil return to pan
Instruction sheet
Thermal wrap
Vacuum hose
Vacuum T fitting
running a self contained one has two downfalls, 1 being space and 2 being running the new water pump most street driven cars do not have the space for this, hence why they are better suited for full race cars.
hmm.. well do u like going back and forth and filling up ur bottle of nos everytime u run out?
personally if i dont get a good deal on a swap and install. i would buy all kind of mod's to build my engine for the turbo cuz i dont mind just slapping 5 grand on the turbo. (run more psi) and build ur car for the track.. like the circuit track and rock some cars.
with turbo its just there when u need. no bottles and ppl respect ya more..
DIY King
Quote
running a self contained one has two downfalls, 1 being space and 2 being running the new water pump most street driven cars do not have the space for this, hence why they are better suited for full race cars.[hr]
Jaryn
May 17, 2016 02:52 AM
