How does "Parking" lock the car's wheels? (AT)
Rep Power: 0 Well, to put it simply, it's an intricate pin inside of the transmission gear box, that when 'selected in park' "pokes" out and engages the next gear cog and prevents it from going forward. Of course the car has to roll a little bit for the pin to engage the next cog on the transmission. Once locked the pin is held into place by a spring and by the wieght of the car pressing against the pin. The pin is tapered so that it can disengage easily when selected to do so. Sort of like, putting a pencil into the spokes of a bicycle wheel. THe wheel will roll until it hits up against the pencil which prevents it from turning. Basically put[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Rep Power: 0 The manual transmission should also be parked using the emergency brake. This keeps the transmission from bearing the full load of the car's weight. I usually engage the parking brake before letting the car roll to it's natural resting possition. That way, if the brake fails for some reason or is disengaged (by a child or something) the car is 'caught' by the transmission. That way, only the emergency brake is handling the full load. And the transmission is allowed to breath a little!
The Standard One
Quote
[hr]Originally posted by: civicsedanlx01
is it necessary to use the emergency break if you have an automatic.[hr]
Quote
-Kre
Rep Power: 0 thanks guys. I've always used it and my friends make fun of me for doing it all the time. And some people tell me that it is putting strain or some bs on my e-brake and I was like whatever dude. So, I continue to use it then.
Rep Power: 0 I think they might not fully understand the physics involved in the braking system. The E-brake actually uses a 'Cam' that pushes the drum brakes against the drum with as much pressure as would be applied by stomping on the brake with two feet. (depending on how tight you pull and the tension of your brake cable)
When the car is standing still, to get it to start moving with the brakes engaged takes quite a bit of force. Much more force than the weight of the car itself! So don't worry, your E-brake is pratically laughing at your request to keep the car still!
Ian SFBA
Interior DIY
04-25-2015 02:25 PM
