Headswap? Is it possible?
Old Jul 21, 2002
THEANTIRICEST's Avatar
Premium Member & 1 Millionth Poster!
THEANTIRICEST has disabled reputation
I know nothing about it. I heard something like "all you need is a head of an engine. For example an SI head (cams basically) and then you swap it with yours and your downtown. I dont know how this works or if its possible please enlighten me.
Keep in mind I overheard this from some ricers at the local shop.
Old Jul 21, 2002
JoeB16's Avatar
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way Galaxy
JoeB16 is an unknown quantity at this point
with your car? no.
Old Jul 22, 2002
with any civic? what does this involve?
Old Jul 22, 2002
anyone???
Old Jul 22, 2002
hondadude's Avatar
hondadude is an unknown quantity at this point
How is the head attached to the cylinder? Isn't there a gasket or something between the two to keep it sealed? And then is it bolted down or what?
Old Jul 22, 2002
WhopSi's Avatar
WhopSi is an unknown quantity at this point
I dont believe its that simple. In order to change a SOHC engine to DOHC, it requires a little more than just changing the head. The timing belt for example would have to be changed in order to fit properly, and a lot of modifications would have to be done to the head to make sure that the cams are coming in contact with the valve springs. It's simply just not that easy, or in other words, its not a "bolt on" modification.
Old Jul 22, 2002
Roy's Avatar
Roy
Roy is an unknown quantity at this point
head swap with doch & sohc is not possible. however, i think that any other sohc head would be compatible. a z6 head would be good if it is possible.
Old Jul 23, 2002
2cute's Avatar
2cute is an unknown quantity at this point
I can not think of any head you could put on the 7th gen vic. It turns the wrong way. As far as the head swap, yes you can take a sohc and put a dohc head on it. ANYTHING can be done it is just a matter of how much you want to spend.
Old Jul 23, 2002
DarrenA's Avatar
DarrenA is an unknown quantity at this point
How much do you think it would cost us to change to DOHC?
Old Jul 24, 2002
RE's Avatar
RE
RE is an unknown quantity at this point
The head off an SI will not work, the K series (and B series if you were speaking of the old SI) engine is completely different from our D series SOHC. Heads are usually only swappable between the same family of engines. You would basically need everything that goes with the head of the engine including the ECU.
Old Jul 24, 2002
2cute's Avatar
Just about the only way to make the 7th gen vic a DOHC is to do an engine swap. Personally I think that single cam has a lot of potential. Of course the 7th gen has none due to the design. The engine was designed for emissions not performance. The engines that could be swaped in are the new SI, the new Integra and the CRV.
Old Jul 24, 2002
FiresVTEC's Avatar
FiresVTEC is an unknown quantity at this point
you can only change heads between the same series block of engine, but even then its a lot of hard work and you would have to be prepared to spend lots of dough. the late eighties integra has a DOHC D series engine, but there has been little talk of that because most people think its not possible or a waste of time. either way, Htown took it upon himself to prove to everyone that K series was possible, so maybe someone could do it with a different DOHC.
jamis33
Jul 14, 2009 07:03 PM
jamis33
May 18, 2009 05:00 AM
greeen01civic4d
15
Dec 31, 2007 09:34 PM
TRIZ
86
Nov 30, 2007 07:36 PM
Redviking
Engine Swaps
Nov 15, 2006 05:28 AM
