two questions...
Old Jul 12, 2002
civicdeveloper's Avatar
civicdeveloper is an unknown quantity at this point
two questions...
Ok, I searched and can't find definitive answers.
1. What's the difference between a 4-1 header and a 4-2-1 header. besides the obvious. i mean the advantages of one over the other.
2. What does bleach do for burnouts?
Thanks!
Old Jul 12, 2002
TwilightX's Avatar
TwilightX is an unknown quantity at this point
Bleach gets everything smoking up real nice...and it helps to have something wet on the tires so you slip on the road better...
As for the difference in headers....um...I used to know, but I haven't had coffee this morning yet, so I can't answer that right now
T-X
Old Jul 12, 2002
civicdude's Avatar
The 4-1 setup is better for racing....especially if you have a stick. If you have an automatic then you need low end performance and you are better off getting the 4-2-1
Old Jul 12, 2002
what's the difference in ceramic and stainless steel?
Old Jul 12, 2002
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
I am not a pro at this stuff but I will do what I can......
The difference between a 4-1 and a 4-2-1 header if the way it connects together.
A 4-1 goes from the 4 pipes of the exhaust into a single pipe
A 4-2-1 is the same as above except it goes from 4 pipes into 2 pipes and then into 1
As for the Ceramic and SS headers I think the Creamic is better to keep the heat in the header pipes so the engine bay stays cooler, but I am not 100% on that, correct me if I am wrong guys.
Old Jul 12, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
i think Crash is 100% right on everything, the ceramic headers are better insulators of heat
Old Jul 12, 2002
TwilightX's Avatar
There's an ongoing debate whether or not the ceramic headers are more prone to cracking or not - personally, I'd rather have stainless steel to be sure and for the looks...
Old Jul 12, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
Yes, ceramic does crack SOONER than steel. But both will eventually crack due to thermal expansion and contraction. It's just a question of when. They do insulate better than the steel, this is true, but unless you are racing in above 100 degree conditions, which you shouldn't be, then the difference is minimal. Also, if you have a CAI it won't matter.
Old Jul 12, 2002
thanks guys. so there's not a big performance difference between the 4-1 and 4-2-1? the 4-1 is better for manual tranny?
Old Jul 12, 2002
Neonmike's Avatar
Neonmike is an unknown quantity at this point
Quote
[hr]there's not a big performance difference between the 4-1 and 4-2-1? the 4-1 is better for manual tranny[hr]
The 4-1 increses torque higher in the RPM range, while the 4-2-1 increases power in the mid RPM range. Depending on what kind of driving you do with your manual, either one could be better for you. 4-2-1 for example would be good for autocross where the RPM sometimes drops to 3-4K. By having that bit more power down low you can accelerate out of the corner quicker.
Quote
[hr]Yes, ceramic does crack SOONER than steel. But both will eventually crack due to thermal expansion and contraction. It's just a question of when. They do insulate better than the steel, this is true, but unless you are racing in above 100 degree conditions, which you shouldn't be, then the difference is minimal. Also, if you have a CAI it won't matter.[hr]
The key here is that the ceramic coating helps to keep that heat in the exhaust gasses so that they don't cool and lose velocity. I would say that a ceramic coated header will make more power than stainless because of this.
Old Jul 12, 2002
damn dude, pretty smart for a noob. j/k thanks! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 13, 2002
merz's Avatar
merz is an unknown quantity at this point
I believe the bleach will soften the rubber up some - help make it sticky - burn-out helps heat them up to temperature for maximum grip.
MECCA60
Transmission
May 17, 2011 09:18 AM
clubcar98
Nov 24, 2010 08:20 PM
Hwoody77
Engine Swaps
May 5, 2005 06:09 AM
SpacemanBob
Jul 7, 2004 05:18 PM
GoBruin02
Jan 26, 2004 03:42 PM
