Rough Idle
Rough Idle
Hello everyone, about two weeks ago my 2005 Accord started to idle weird so I took it to oreillys and got a code for misfire and so I changed the park plugs. However that did not change the idling issue and ever since the car idles roughly before the engine stalls and turns off.
i can keep the engine on by pressing the gas, I have taken it for a drive but the acceleration is weak and the rpm’s drop to 500 once I come to a full stop and again the engine shuts off.
i replaced the vvt solenoid because that’s what P1009 code was telling me to change but after the change of part it did not fix the issue.
Re: Rough Idle
Re: Rough Idle
it was a doorman brand I believe, I will say that if I unplug the solenoid the engine is a lot more stable. As soon as I plug the terminals the engine idles roughly and eventually stalls and turns off.
Re: Rough Idle
Dorman?
Junk. Toss and buy an OEM Honda one.
Junkyard is your friend if you don't want to pay the price of a new one.
Re: Rough Idle
is it that bad? I can always put the old one back because at this point I don’t think that was the problem. I just went with what the code had affiliation with.
Re: Rough Idle
The new aftermarket is clearly the problem, put the old one back and see what happens. I would grab a junkyard one.
we have a new thread almost every day where someone puts an aftermarket sensor/solenoid on their car and suddenly have problems
Re: Rough Idle
cheers!
kateri.bean
Sep 19, 2017 11:21 PM
Civic LX of Tim
Oct 27, 2016 07:16 AM
