Piston rings bad?
Old Apr 20, 2020
Roberts634's Avatar
Roberts634 is an unknown quantity at this point
Piston rings bad?
The filter on my valve cover is smoking, and there is excessive amount of air coming out of the valve cover when you take the oil cap off. Would this cause loss of power and is it my piston rings?
Old Apr 20, 2020
FRSam's Avatar
Click Here
Re: Piston rings bad?
It's almost definitely rings, which lowers compression, which lowers power.
Depending on what car you have, I would just drive it unto into the ground, and refill your oil as necessary. Replacing piston rings isn't easy/cheap.
Nascarhaidek
Apr 14, 2018 08:48 PM
TeraCivic
Aug 28, 2008 09:26 PM
exturbo6
Engine Swaps
Aug 18, 2007 03:19 PM
juscallmetoyota
18
Aug 12, 2003 01:12 PM
CivicGoh
Canada West
May 15, 2003 02:52 AM
