Throttlebody change
Old Sep 27, 2019
Nickyggg's Avatar
Nickyggg is an unknown quantity at this point
Angry Throttlebody change
Throttlebody change I have a 2012 Honda accord Ex 3.5 v6. I change the throttlebody then when I put the new throttlebody in When I turn the wheel back-and-forth the tachometer surges and when I’m idling it’s running at 700 rpm’s And when AC is on the tachometer jumps up a little bit I can’t figure it out And I tried to do the steps to re-learn that throttlebody the new one and it did not work reset the computer I tried everything I can anybody help thank you appreciate
Old Sep 28, 2019
Re: Throttlebody change
not a Civic, not a 10 gen (start at 2016 model), so moving thread to general automotive discussion
Old Sep 28, 2019
Why did the throttle body get replaced?
Put the original TB back on it, see if problems go away.
Try disconnecting the battery for 15 minutes before attempting idle learn,
Probably need a professional or dealer level scanner to do the relearn processes.
BlueEM2
Idle Issues
70
Jun 20, 2023 08:34 PM
BlueEM2
Engine DIY
44
Oct 28, 2017 02:53 AM
DownfallEclipse
Apr 21, 2011 01:20 AM
honestlarry
Apr 25, 2010 10:52 AM
fathan16
Oct 12, 2007 04:30 PM
