Throttle body spacer and idle problem
Old Oct 12, 2007
fathan16's Avatar
fathan16 is an unknown quantity at this point
Thumbs up Re: OBX Throttle body spacer and AEM CAI
I got an obx tb spacer, it didnt really have any instructions can anyone tell me how to install it. i tried to install it, but now the cars rpm's bounce around at idle, from about 800 to 2500. i have a 95 dx civic, if anyone can help, i need it badly
Old Oct 12, 2007
TRIZ's Avatar
Re: Throttle body spacer and idle problem
moved to new thread.
Old Oct 12, 2007
you need to reset the ecu and do the idle learn. make sure car is warmed up, disconnect battery or pull FIECU fuse, put back, start car and let it idle without using any accessories or pressing gas for 10 mins. turn car off. should be fixed. if not, throw away the spacer.
Old Oct 12, 2007
clue14's Avatar
clue14 is an unknown quantity at this point
I Love When People Are So Helpful!!!
Good **** You Just Got Kudos!
Old Oct 12, 2007
familycar's Avatar
you may also have a air leak . this could also be the cause of inconsistant idle. i would make sure all bolts are tight and spray around the tb with some carb cleaner and listen for changes to idle
Old Oct 12, 2007
hmm ya did the spacer come with new gaskets? cause its not a good idea to reuse the old ones which are too flat already.
davidpaustin
Apr 29, 2015 02:23 PM
green01civic
Apr 29, 2015 01:36 PM
mievil
Apr 28, 2015 11:02 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
