2008 CRV rear vibration only with driveshaft installed
Rep Power: 0 2008 CRV rear vibration only with driveshaft installed
Any ideas on what may be causing an annoying vibration at approx 50-60 MPH but only when driveshaft is installed. Replaced w/ new driveshaft and confirmed driveshaft is balanced. Rear bearings replaced. Tires balanced Anyone have this elusive problem. Could a rear differential be at fault?
Re: 2008 CRV rear vibration only with driveshaft installed
A clue could be in the harmonics. Resonant reed tach, or electronic vibration analyzer?
What is the speed/frequency of the vibration? What components in the car are operating at that same speed?
Exhaust noise? Heat shield noise?
Those rear diffs have given me zero problems--- other than they can rumble and groan during slow and very tight turns if the fluid is overdue for service.
Received 1,442 Likes
Rep Power: 338 Re: 2008 CRV rear vibration only with driveshaft installed
not a civic, wrong generation, so moving to general section...
jessica19699
04-19-2017 12:49 AM
babzog
05-06-2009 02:36 AM
civic es1
11-23-2004 06:39 PM
cdub604
04-11-2004 11:46 AM
