Rear of car rocks side to side
Old May 3, 2009
babzog's Avatar
babzog is an unknown quantity at this point
Hey folks,
I replaced my rear struts a couple of weeks ago and I notice when I'm driving slowly over bumps, that there is a knocking (for lack of a better word) noise, very soft, coming from the rear end (tending toward the passenger side). I also notice that the car rocks easily side to side (and takes 2-3 oscillations to stop) in the rear end and there are noises I can hear (like something's knocking about back there). Bolts were torqued to spec when I reinstalled (43 top, 45 bottom).
Not having a prior frame of reference to go by (not like I make a habit of rocking my cars for kicks), is the rocking motion I described above normal? What do you think the knocking sound could be?
Cheers!
Old May 5, 2009
mrplow123456's Avatar
mrplow123456 will become famous soon enoughmrplow123456 will become famous soon enough
Re: Rear of car rocks side to side
I highly doubt it's normal, but my car does it as well. I know that it is most likely a suspension problem. You said you replaced the struts, what about the springs? Also, a rear strut bar may help if you don't mind the inconvience. I believe it comes it our cars aging and i believe the lack of care on certain suspension components. If you are rly desperate to eliminate the noise, replace the entire rear end, lol sounds drastic but better to eliminate the noise.
Old May 5, 2009
the 92 accord we have does this when you close a door lol. you can see it jiggling side to side for a few secs. its prolly cause the shocks are blown.
Old May 5, 2009
babzog's Avatar
I replaced the entire rear strut assemblies - shocks, prings, mounts, etc - with an all-new assembly from my local parts store (already assembled - just swapped them out).
Old May 5, 2009
what about front ones
Old May 5, 2009
babzog's Avatar
Did the fronts first, couple of weeks before the rears. I took your advice and changed the rears even though they weren't leaking anything. Figured they were old enough that they'd done their duty.
Old May 6, 2009
Only thing else I can thing of are lca's, sway bar, maybe even some bolts came loose. I had some body work done to the read of the car and they never cleaned the damn thing out. I found prolly 6 black bolts that I talked to someone and they were meant to keep the body attached to the frame. My only question is now, did they put new ones back in???
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ej8
Apr 13, 2015 06:36 PM
JackTripper
Nov 7, 2001 09:04 PM
ImmortalEX
Oct 31, 2001 10:00 PM
