Help. 2001 Olds Aurora headlights stay on.
I am trying to help a friend with his 2001 Aurora with V8. His headlights stay on all the time. He has to disconnect his battery to turn them off. He gave me a Haynes manual to look over but even though the manual covers up to 2002 it is not like his car. Anyway in looking up the problem it is usually either the Multi Function Switch or the Lamp Control Module. I have found out that they did away with the LCM in 1999. Anybody know if they replaced it with something else and if so where it is located? A wiring diagram would be great. I pulled a MFS at the junk yard today and it is not one of the easier ones to change. I want to be sure that is the problem before I tear into his car. I grabbed a few relays from under the hood to give a try. Any help would be appreciated. Thanks
Ed
Ed
Re: Help. 2001 Olds Aurora headlights stay on.
I can't get Alldata at home, sorry. If I remember and have time, I'll try to look at work tomorrow.
Ed
At least with the schematic I can tell if it is the MFS or not. It is not easy to change and the car is real nice. I don't want to scratch or break anything. 35+ Years Driving Japanese Autos
Check if tails are on also, & look to see if just high beams, or just low beams on maybe stuck relay contacts.
Looked around a automotiveforums.com but you may check there 105 pages on this olds model.
As far as I know it is just the headlights. I haven't even been to his house yet, just trying to reseach and get what I may need. I pulled the MFS and a module out yesterday. I looked up the number on the module and is said it was the body control module so I took it back. I keep finding confusing info. Some say that is the module I need, some say there is another module called DIM(dash integration module). Like I say, nothing is ever easy for me. I also read that all these modules are VIN specific and if I get one in the JY it may not work.
At least with the schematic I can tell if it is the MFS or not. It is not easy to change and the car is real nice. I don't want to scratch or break anything.Ed
Headlight switch only makes a request to the DIM (dash integration module).
DIM controls the low and high beam headlight relays and the DRL relay in the underhood fuse block.
Yeah, you really need to know exactly what all lights (and anything else unusual) are affected before you start chasing stuff.
If it isn't a stuck relay then it's probably a control side that won't let go..And everything kinda looks like it leads to the DIM as the control point.....
A Tech2 scanner would give access to data and possible codes, that would surely cut down the dinking around time.
DIM
Above right dash hush panel, looks like 3 connectors
I'd guess a box the size of a PCM?
EDIT: No idea if it would need programmed or not.
Ed
Thanks Ezone and Matt, I really appreciate all the help you guys give to us hacks. I think I will go back to the JY and grab the modules. I think that DIM is behind the glove box. They are only about $10.00 so I won't be out too much. I still need to find out if they are plug and play.
Ed
Ed
Ed
jbradley4809
Apr 7, 2017 04:23 AM
Ma213802
May 18, 2015 07:01 AM
