HELP Me 1998 honda CR-V 2.0 turns but will not start
Got a 98 CR-V turns but will not start i checked the end of the number 1 plug an its firing. unbolted the fuel filter it sprayed so i think its gettin gas ran a OBD 2 scan on it came back p1298 ELD circuit high input and p1768 automatic transaxle fault need help bad.Any Suggestions Greatly Appreciated.
Re: HELP Me 1998 honda CR-V 2.0 turns but will not start
Usually other codes are because of the bad ELD. Try replacing the ELD first. Your either gonna have to buy the whole fusebox new from Honda ($200) or salvage ($50-75). Or pull an ELD out of a you-pull-it yard.
This is your ELD:
*Remember to disconnect the battery negative cable before starting work.
This is your ELD:
Live for the Twisties
This is a Civic forum, not a CR-V forum.
If you need help diagnosing your issues then please find an appropriate forum such as Hondasuv.com.
jessicakaybby
Apr 20, 2015 12:11 PM
SSMatey
Apr 13, 2015 06:09 PM
gabrown2
Apr 11, 2015 08:22 PM
Bartkat
20
Feb 19, 2002 01:29 PM
