general question regarding manual transmission
Old Sep 4, 2005
LakeShow's Avatar
LakeShow is an unknown quantity at this point
on all the cars, do you have to hold down the clutch in order to turn on the car??...i know this applies to my civic, but i just wanted to konw if you had to do that on all cars wit stick shift
Old Sep 4, 2005
sp3cialk's Avatar
sp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of light
i believe you do.
Old Sep 4, 2005
LakeShow's Avatar
another thing...Im doin a process speech on how to drive a car with manual transmission....Wat do you guys think my visual aid should be?...i was thinking about making a transparency of the pedals...show'em which is which and wat to do??...but im not too sure...ANYONE else got any ideas??
Old Sep 4, 2005
wheamahm0n3yat's Avatar
wheamahm0n3yat is an unknown quantity at this point
yup you do, but mines dont have to, because i have remote start. the clutch sensor is tricked to where it seems like you applied stepping on the clutch
Old Sep 4, 2005
saugashan's Avatar
This is not my batman glass!!
saugashan should not be trustedsaugashan should not be trustedsaugashan should not be trusted
nop my dad had a sonata, it didnt need the clutch pressed in, adnd no he didnt have a remote start
Old Sep 4, 2005
streetglower's Avatar
depends on how old the car was. Newer cars are required by law to have a safety switch that when you go to start your car, either you have to press the brake to start it, or hold down the clutch in a manaul tranny. As automatics have a switch that prevents you from putting it into gear unless you press the brake and manauls have a neutral safety switch so it can only be started with the clutch pedal pushed in. they did this because people used to start there car in and would go through walls, crash, etc...
Now the only other way is if you rig the system to override those switches.
Old Sep 4, 2005
slammedcivic85's Avatar
Member
slammedcivic85 is an unknown quantity at this point
Talking
they arent tricked to where is seems like you are stepping on it the whole clutch and that safety feature has to be overrided in order for the remote starter to work basically its forced to work like an automatic car and the car thinks it has no clutch when its being started. Sorry it probably sounds like what u meant but i just wanted to get a lil more in detail with it. I too dont need a clutch i have a remote starter to override mine
Old Sep 4, 2005
i guess thats what i was trying to say, but couldnt figure out the words..lolz
Old Sep 4, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
you can remove that if you want. There is a little yellow harness near the pedal what is activated when the clutch is pushed in allowing the car to start. If you cut that harness off and cross those two wires, it thinks the switch is always closed, there for no need to hold the clutch to start the car. Its only for safety anyways. The plus side is you can install remote start, or start your car from the passenger seat.
Old Sep 4, 2005
Blahman240's Avatar
Originally Posted by streetglower
manauls have a neutral safety switch so it can only be started in neutral.
do me a favor... go put your car in 1st and try start it... There is no such switch.
Old Sep 4, 2005
Member
lmao good observation i didnt even realize he said that i guess i just chose to ignore what he said lol
Old Sep 4, 2005
what I mean to say is there is a switch that only allows you to start with the clutch pedal pushed in. It is called a clutch safety switch, clutch interlock switch, neutral safety switch, all serve the same basic purpose. Sorry if it came out wrong, they can be started in any gear though.
Old Sep 4, 2005
Member
thats better stated streetglower we all make mistakes
Old Sep 4, 2005
LakeShow's Avatar
thank you fellaz for answering my question...any ideas on wat visual aide i should use
Old Sep 4, 2005
Member
Im kno school teacher but try using one of those ps2 or xbox steering wheels with the pedals lmao just a thought lol especially if you actually have them laying around
Old Sep 5, 2005
DDragon7's Avatar
Is the transmission going bad if its hard to shift into first? Cuz last night I was having an especially hard time (jus once) trying to get it into first from start and today had a lil problem going to second from first once also.
Old Sep 5, 2005
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
use a bike its the same concept as clutch and gas, when one foot is down the other one's up, and u have to synchronize them with ur feet to get the car moving.
Old Sep 5, 2005
LakeShow's Avatar
lol..i have no bike and have none of those PS2 pedals..lol..i was thinkin of making a transparency of the pedals, and show them which is which and wat to do ???
wat yall think?
Old Sep 5, 2005
dma001's Avatar
dma001 is an unknown quantity at this point
If you have access to a video camera, and you can get someone to help, then I think the ideal visual aid is a video of the shifting process. I've tried to describe it to people, but they usually don't get it until they actually watch me shift, then they usually say something like, "Oh, THAT'S what you were talking about!"
Old Jan 13, 2006
Eclectic's Avatar
Eclectic is an unknown quantity at this point
can someone please explain why the car is more prone to jerk when shifting to second gear instead of the higher gears?
my friend says it's because the rpms aren't kept constant and can drop when you let go of the gas to shift to second. he said just blip the gas a little when you are holding the clutch down before shifting to 2nd. however, other people say they just hold the clutch halfway and gas as if it were 1st gear and trying to make it catch. which one is better for the clutch?
thanks
Old Jan 13, 2006
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
because the relationship between the speed of the wheels and the engine is greater in lower gears. So its going to have the largest reaction.
not all cars must have the clutch in to start. I had an 82 f-100 that had a strong enough starter where you could put it in gear and the starter would do the equivalent of push starting it with the clutch let out.
Old Jan 14, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
practice on a real car. there is no susbstitution for experience. good luck. it took me about 3 days to stop chirping in 1st. took a week to quit stallin. the rest you learn as you go.
Old Jan 14, 2006
Matty Civics's Avatar
Matty Civics is an unknown quantity at this point
dead *** took me 2 days (combined total of like 3 hours) in my buddys accord to not stall and get it into 1st and upshift and downshift perfect. Its almost like I had done it before. Guess he was just a good teacher.
In response to the post above about going into second, when I drive his car and when he was teaching me, he always told me when u shift to second, clutch in, shift, lil gas and lift clutch half way till it catches and then let go of it. This is for normal driving of course.
Screw parents of course, according to them in only 18 and driving a manual is very very dangerous, even though they sure as hell knew I understood and could drive it fine.
Well Im only at 2800 miles in my civic, Im waitin til 10K or 15K and then manual swap, here I come.
Im tired of the car driving itself. I cry every time I see only 2 pedals.
Old Jan 14, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
thanks
inertia
Old Jan 14, 2006
ddevil0013's Avatar
You gotta be as blind as Anne Frank not to see that
ddevil0013 is on a distinguished road
for a visual aid, find one of those racing vids they have floating around that shows like 3 camera angles in one frame..the padal, the shifter and the driver. i learned heel/toe by watching rally racers this way
Old Jan 15, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Check out my thread on driving manual transmissions, it may interest you guys. I know some of you have already read it, and would appreciate it if you would pass it along. I would like it to be stickied because every week maybe even more often someone asks the same questions,
http://www.7thgencivic.com/forums/sh...d.php?t=242566
Old Oct 30, 2011
pnamajck's Avatar
pnamajck is an unknown quantity at this point
Re: general question regarding manual transmission
if you cut that harness off and cross those two wires, it thinks the switch is always closed
thanks for the good info, blahman240 . . . worked for me. got 292k on my 2002-c . . . guess the contacts were just wearing out. no longer need to depress the clutch . . . 'ppreciate your knowledge.
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
jackshepardjr
May 24, 2015 09:53 PM
viper775
Dec 9, 2001 10:52 PM
supercivic01
South
Nov 30, 2001 11:27 AM
