Window relay location pls???
Hey hey y'all. question. Does anybody know where EXACTLY the 2002-2005 Acura EL/Civic with auto window up/down relay is located??? I jus don't wanna start pulling things apart until I know for sure and YES I did do some searchin with no luck. All the help is WELL appreciated. Thanks in advance
Re: Window relay location pls???
Number 2 is the regulator
For the relay, find the fuse box under the steering column. I think its a number 9.
Thanks a million. But quick question tho. I want to add the auto up/down function in my car. Before I do anythin I wanna do my homework. What will I need to do to get this to work for me?
530T won't replace anything at all. It is wired between the switch and motor. But it will read the signal from your switch and give you auto up/down on both motors you hook up.
Hey u got MSN cause I really dun wanna flood this up but lemme kno if u do cause I got sum nOOby questions but not a lot.
Thaik
Electrical
Jul 9, 2015 01:51 PM
Touge
Jul 1, 2015 11:38 AM
Touge
Jun 18, 2015 11:44 PM
Touge
May 20, 2015 10:53 PM
