Crower Stage 2 cam dyno tune part 2
Old Jul 23, 2007
ronaldo9's Avatar
Ok folks, the first dyno run in November was horrible. I redid my map and the car ran better but I needed to get on the dyno to work out some bugs. I'm still not putting out anything impressive but nevertheless numbers are numbers. Still saving up for that standalone.
http://s132.photobucket.com/albums/q...t=cad7b3e1.flv
Old Jul 23, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
Re: Crower Stage 2 cam dyno tune part 2
stock engine, then running a crowner stage 2?? almost 7 ponies
Old Jul 23, 2007
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Did you just have new dyno run?
With header, exhaust, intake, cam & emange, I'm estimating 130whp.
I've also heard, that iVtec cant be controlled with emanage blue?
Old Jul 23, 2007
TRIZ's Avatar
Looks like I'm not the only one jumping on the dyno.
BTW, I went with stage 2, in the build as we speak- just got some base numbers.
I'm seeing 2,000 rpm increase. I thought it maxed rpms at 8,000- and stage 3 was 9,000. I guess thats just a suggestion, I never heard anything as to why you would do that. ???
Anyways, your running the valvesprings too correct? Did you upgrade the valves or valve seals?
Old Jul 23, 2007
Holly!
Just realized you are spinning to 8500!
125whp, definitely on the low side.
Was vtec on during the run?
I think your megan header is killing your top end power.
Try borrowing kamikaze race header and compare. You should see better numbers.
Old Jul 23, 2007
ronaldo9's Avatar
Woah Woah, sorry for the confusion guys. The first run numbers was how I came in before the tune (my street map that I made with the wideband). If you all don't remember I made 107whp 98tq with the megan header and stock cat. Now I am running the hp header and test pipe. I redline at 6800k or w/e the ecu goes to on the EX but as you can see the cam is still making power at redline so the car is just asking to rev more. Triz congratulations on the cam purchase. I bet you'll put higher numbers than me. I just have bad luck when it comes to this crap but ya I have the valve springs and retainers but stock valves.
Old Jul 24, 2007
rick1574's Avatar
rick1574 will become famous soon enough
i must have missed the first thread about this...what ems are you using?
Old Jul 25, 2007
ronaldo9's Avatar
Running emanage for now, not the best but it does its job adding fuel. Honestly, I think a VAFC 2 might do a better job. Curious to see if the car runs smoother with the Greddy pressure sensor and tune off manifold pressure instead of throttle position.
Old Jul 25, 2007
exturbo6's Avatar
not bad ian. maybe instead of going turbo, u shoud just buy high compression pistons and rods, and have some fun all motor.
when i took my car to turbo trix to get tuned when i was turbod, i made 108hp...b.c they couldnt tune the e-manage. idk. looks good thou.
Old Jul 25, 2007
TRIZ's Avatar
So wait, whats up with your rev limit at the moment? Did the dyno just not get programed right when you pulled up, and is reading the revs on the high side?
Old Jul 25, 2007
lordhelmet's Avatar
It looks to me as though revs arent even shown on his dyno. 85 mph, not 8500 rpm.
Old Jul 25, 2007
TRIZ's Avatar
Oh psh, LOL- my bad. So then you havent pushed your rev limit up yet then..
Third gear pull right?
Old Jul 25, 2007
LT2004ever's Avatar
how do u tell the rpm's from that pic??
Old Jul 25, 2007
ronaldo9's Avatar
Yes, it was a third gear pull but I think he could have even revved it higher bc I know for a fact my 3rd gear tops out at 90mph;I've tested this on the street.
Old Jul 25, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Keep it up...
It sounds frustrating...
Old Jul 25, 2007
ronaldo9's Avatar
It is very frustrating I told Dailydriver1 that I'm not sure if I just have A.) a weak engine, B.) bad tuner C.) emanage limiting the horsepower.
Old Jul 25, 2007
02BLKCIVIC's Avatar
In my opinion a bad tuner...
Good luck...
im going through some fanatical issues now every day i look at my cam though...
lol
Old Aug 3, 2007
LogicWavelength's Avatar
7th Gen Photographer
LogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of light
I really don't want to hear "bad tuner." Ronaldo9 - you know my problem. Is Turbotrix doing your e-manage tuning or did you bring someone else there? I'm thinking of just driving to friggin' NC and paying Chris a visit at this point I'm so pissed off.
Old Aug 3, 2007
02BLKCIVIC's Avatar
that would be cool as hell^
Old Aug 3, 2007
civic-driver's Avatar
civic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond repute
has anyone with the stage 2 tried the AEM F/I piggyback? i know its new but i dont think i have heard of anyone using it except for turbo. im curious to see if it would fare better than the emanage. i have heard basically that the emanage is a waste of space in the car just because no one can really tune it correctly and even if you can it never works like its supposed to.
Old Aug 3, 2007
djmota's Avatar
I highly doubt you are going to get any more hp with more dyno tuning time. e manage is just a tiny step up from vafc2. check out my all motor dyno at ams on a dynojet. its pretty close to what you are getting with a few less mods than me.
Old Aug 3, 2007
Da1lyDr1ver's Avatar
^^^ did you get your car tuned at Church's (according to your sig)???
what mods do you have on your car for all motor?
if you did get your car tuned at Church's, i've heard that their dyno numbers always read higher than other shops, if so your results may not be "on par" with our numbers.
Old Aug 3, 2007
djmota's Avatar
The dyno above is from a shop called AMS in irvine. That is without hondata. only vafc2 tuned by me.
Recently when i got hondata, it was tuned at church's but thats a completely different time and dyno.
Supramk3
Jun 11, 2015 11:13 AM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
Tybonater
Apr 24, 2015 07:03 PM
CivicVoz
Apr 16, 2015 08:07 PM
thesushiboy
Apr 12, 2015 07:40 PM
