my DIY dash looks like sh*t
Old Mar 13, 2002
insan's Avatar
insan is an unknown quantity at this point
i don't get it......i'v painted suff before. i use the same silver thats on the trim around in the car..first i lightly sanded it then panted the center and the side vents. it looks all rough. i'll just have to buy new peices and get me a dash sticker set. this sucks..........
Old Mar 13, 2002
fraga's Avatar
Wicked Moderatuh
Well I guess that's what happens sometimes when you DIY. Results NOT GUARANTEED.
Old Mar 13, 2002
PerfectD3's Avatar
PerfectD3 is an unknown quantity at this point
Um, doesn't sound like you used primer nor any kind of clear coat.
Old Mar 13, 2002
AzNmiKex215's Avatar
2k1civic.com O. G.
sand it down with really fine sand paper.. and try to sand it under water.. maybe that will help smooth it all out.. so u can repaint it.. thats wut im plannign to do.. i did silver and some of it is crappy..
Old Mar 13, 2002
LOWBOY's Avatar
LOWBOY is an unknown quantity at this point
Yeah, if you didnt use any primer before painting, thats why.
Old Mar 13, 2002
pimpdakota's Avatar
pimpdakota is an unknown quantity at this point
<< Yeah, if you didnt use any primer before painting, thats why. >>
I have to call b.s. on that remark!!! you dont need primer and you shouldnt have sanded it! You should have
1= take peices of dash and used a wax and grease remover or some sort of paint prep. to eliminate all of the armor all or dash dressing!
2= scuff lightly with some very fine scotch brite pad or steel wool!! VERY VERY fine!!!!!
3= use wax and grease remover and or paint prep again on the surface!
4= dry completely!!
5= use a tack cloth or a air blower to remove scuffing dust and micro particles!
6= spray a very fine dusting of paint onto surface! Very light!
7= once first light coat is dry then start your coverage coats!
8= Use light coats, so you dont run the paint!
9 = use as many coats needed for adiquate coverage! just dont spay too much at one time or it will run!
10= let paint cure completely before handeling! When i say completely i mean spray at night and dont touch till morning! just to be safe!
If there is any trace of armor all residue on the surface of the peices being painted, paint will fish eye and not lay out like you would want!!
Dakota
Old Mar 13, 2002
Voiceofid's Avatar
End Bringer
i primered it, looks great[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Mar 13, 2002
Jochij's Avatar
Jochij is an unknown quantity at this point
it turned out like that becuz u used a very strong sandpaper for plastic dont use sandpaper period cuz it will make it look all roughj and nasty just clean it with alcohol very good and it should look all dull and ready to prime and paint.
Old Mar 13, 2002
WhopSi's Avatar
WhopSi is an unknown quantity at this point
pimpdakota: you couldn't be more right. thats exactly what I did and mine came out great
Old Mar 13, 2002
avenger's Avatar
avenger is an unknown quantity at this point
ymmv [IMG]i/expressions/beer_yum.gif[/IMG]
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
cferry7
Oct 18, 2015 06:32 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
speedlever
Sep 24, 2015 07:18 PM
