Should I...
Old Mar 1, 2002
Hwoody77's Avatar
Hwoody77 can only hope to improve
Should I...
I'm going to the track tommorow, should I change my oil for the first time? I have 27xx miles on my car, and am thinking if I changed the oil, I might get a better time. Also, when I lower my tire pressure, should I do it before or after the tires are warmed up?
Old Mar 1, 2002
ricerocket's Avatar
ricerocket is an unknown quantity at this point
an oil change might help..but i don't think the tire pressure will make that much of a difference our cars will only go that fast...if you want to u can go hard core... 1/3 of your tank filled up, no washer fluid, and take out your chairs....
Old Mar 1, 2002
Grey's Avatar
DIY King
No! The oil and filter that are in the car should be there for at least 5,000 miles. My understanding is that the oil from the factory is specially formulated to help break the engine in. The filter is slightly bigger than the ones you'll put in later and the oil has some kind of additive that helps to get rid of the metal filings generated by the engine components grinding against one other. As I understand it, the imperfections that are inherent within the various engine components (because of the limits of manufacturing tolerances) will be smoothed away so that they can mate up properly to one another.
Old Mar 1, 2002
avenger's Avatar
avenger is an unknown quantity at this point
^ what grey said [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
its true
and regarding going to the track, dont worry about tires etc... because if you actually want to do something wait till the first oil change, dont go ripping up the engine on the initial oil
Old Mar 1, 2002
Toad's Avatar
Toad is an unknown quantity at this point
yeah.. i would hold up on the track until you do your first oil change past 5 - 6,000 miles...
but do whatcha gonna do.
-Toad
JetsterDajet
Aug 16, 2015 01:56 PM
an00bis
18
Aug 1, 2012 02:44 AM
mkollek
May 23, 2009 02:50 AM
DJ Silkie
35
Jun 4, 2007 01:08 PM
milba
Jul 12, 2005 10:16 PM
