WARRENTY
Old Feb 28, 2002
XjIgGyBoNE's Avatar
XjIgGyBoNE is an unknown quantity at this point
WARRENTY
If a honda dealer voids your warrenty, then do they void out every part of the warrenty or just that certain part of the warrenty that they will not fix as a result of the mod causing the problem?
Old Feb 28, 2002
2k1BlackBeautyOwner's Avatar
2k1BlackBeautyOwner is an unknown quantity at this point
First of all, it WARRANTY....not warrenty. But I think it would void your whole warranty, then again, it wouldn't hurt to give them a call and ask. But I'm quite sure it's the whole thing.
Old Feb 28, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
A Honda dealer won't void the warranty unless you make them work on a part of your car that's modified. It's up to you if you want them to fix it but it's at the cost of your warranty. And it depends on what they fix... if you've worked under the hood, and there's a problem, they have to prove the modification was the cause.
Old Feb 28, 2002
SoNiCcIvIc's Avatar
Every dealer is different about warranties... you should ask them what you can do to your car before you mod it. Some dealers don't allow ANY modifications and blap... cleared headlights=voided engine warranty... (nah, it won't be THAT intense but check just in case!)
Supramk3
Jun 11, 2015 11:13 AM
Thees1
Apr 14, 2015 08:23 AM
gabrown2
Apr 11, 2015 08:22 PM
ddongs
May 16, 2003 12:20 PM
XjIgGyBoNE
Feb 27, 2002 05:25 PM
