WHen should I change plugs?
Old May 14, 2006
flqu05's Avatar
flqu05 is an unknown quantity at this point
I have 36 k on the car.
Old May 14, 2006
CenZ's Avatar
PWIT
not for about another 54k
Old May 14, 2006
CraigW's Avatar
My plugs are at least coming out for inspection (and probably replacement) at 50-60k. I would never leave any plug in place for 100-110k they may not come out at that point.
Old May 14, 2006
CenZ's Avatar
PWIT
the manual says 90k
Old May 14, 2006
YUL's Avatar
YUL
YUL has a spectacular aura aboutYUL has a spectacular aura about
yea, whatever the manual says.
90K is right. you're just wasting $$ by replacing them before.
Old May 14, 2006
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
i checked mine out at about 60K miles, they looked brand new. i will probably check them again around 95k.
Old May 15, 2006
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
crap, I have 104k. I should check them.
Old May 15, 2006
dp_yz713's Avatar
Boobies are the mans tinkertoys
dp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to behold
its not as if its a 2 stroke that you can run rich or lean and can file plugs. as long as it starts up without hesitating your good
Old May 16, 2006
kevncar's Avatar
kevncar is an unknown quantity at this point
come on guys/gals. I thought these Honda's were the best thing since sliced bread. I just got around to changing the plugs in my 96 Crysler Cirrus Lxi at 171,000, and only picked up 1 mpg. Oh-well, I'm hoping to replace it with civic shortly after it gets to 200,000. This things been costing me way to much money.
Old May 16, 2006
wow cant believe you guys wait that long. those platinum aren't as good as they say. i change mine every 5-6k but i have copper plugs now.
Old May 16, 2006
diskreet's Avatar
is there a link to a quick DIY on installing them? I don't have a torque wrench. J/W, even though I probably won't change them, but I did just get a ton other stuff so might just for the heck of it.
Old May 16, 2006
well you kinda need a torque wrench or you wont know how tight to make it. otherwise quick diy, remove wire cover, remove coil packs, remove plugs. fairly easy. you need a plug socket tho to loosen them. then can stick the coil pack in to grab it.
Old May 16, 2006
KINGCHILE's Avatar
KINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to all
May Not Apply To Thread But Go With Iridium Plugs.
Old May 16, 2006
diskreet's Avatar
oh then Ill just get them replaced as scheduled by the garage at a later date. thanks gearbox.
Old May 20, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
heres a link to my plugs after 90k. they can last to the recommended interval no problem.. but you might lose power and mpg after awhile. if i had to do it over again, i wouldve changed them earlier. probably @ 60k. so id say wait 24k.
http://theoildrop.server101.com/cgi/...;f=24;t=003511
Old May 21, 2006
flqu05's Avatar
The dealer wants 20.00 a plug...ill wait.
Old May 21, 2006
ctx66's Avatar
sparkplugs.com charges around $7 each. its a newer version though. probably not any different at all.
Old May 21, 2006
i got my ngk v-power for $8 (box of 4). its been 5k miles and it still feels good. gonna change em anyway cause whats another $8 every oil change.
thana
Jun 15, 2020 07:05 PM
docmartin14
Jul 30, 2015 11:26 AM
mrohitredd
May 28, 2015 10:03 AM
RIPSAW
May 23, 2015 04:03 PM
silverdevil
20
Jun 2, 2007 04:42 PM
