Best for Carpet Cleaning
Old Apr 5, 2006
eggfooyoung's Avatar
eggfooyoung is an unknown quantity at this point
I have winter road salt on to my carpet and wanted to remove it. Are there any products out there that will remove salt from carpet or is hot water and a brush the best way to go?
Old Apr 5, 2006
teg91ls's Avatar
teg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trusted
If you are going to clean your carpet with water and a brush, you need to remove it first, because the padding under the carpet will take forever to dry and will start to stink
Carpet is overrated anyway, i ripped mine out.. OEm floor mats are good enough.
if you do decide to clean it a product called "oxyclean" works good you can find it at walmart with the steam cleaner section.. or the regular coral blue stuff you get in the auto section works good too, but like i said, i would remove it to clean it, unless you have a very powerful steam cleaner to suck up all the water
Dave Brabant
20
Oct 6, 2015 12:44 AM
wingsfan19
Oct 1, 2015 03:45 AM
Sep 27, 2015 11:33 AM
Balkos
Sep 11, 2015 11:39 PM
Bricoleur
Sep 9, 2015 12:30 PM
