Gearing
I Hunt Goats, Rams, And Mustangs.
Gearing
Okay this has been puzzeling me for a while. Before i did the engine swap from my D17A2 to my current K20A.. when i would be driving down the free way, i would sit about 80mph @4200Rpm, even though i have switch from a 5spd to a 6spd it still runs the same Rpm for the speed.. I belive that the final Drive on the 5spd was 4.41 vs the 6spd which is 4.73.. so how can it still be the same speed for rpm?
that is a interesteing point I know if i'm running 80 with my k20a2 I sit at about 3k rpm.. or hover in that zone in 6th.. i'll have to go searching on that myself
4 cyclinders down, 4 to go.....
the gears in the D17 tranny and the K20s are different. All things being equal, as long as the tranny gear and the final drive multiply to give you the same number then you will run the same speed.
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
BBrosario
Sep 17, 2015 07:51 PM
