1.7 El engine Vs. EX(Si) Engine
Old Feb 12, 2002
CivicMonkey's Avatar
CivicMonkey is an unknown quantity at this point
Just wondering if the 2k1El engine has the same engine as the 2k1 Si, bc they're both SOHC Vtec.
and one more quick question, why did the regular civic gain 8 hp w/ the new 1.7 engine, but the new Si engine still only has 127hp, even w/ the new 1.7 engine
Old Feb 12, 2002
KurupTLX's Avatar
KurupTLX is an unknown quantity at this point
Hmm interesting question.. im not sure what they did to the LX, DX engine to squeeze out the extra 8hp
But as for the EL and the Si... Yes they are the exact same engine
K-lx
Old Feb 12, 2002
Rebew1's Avatar
Rebew1 is an unknown quantity at this point
It all has to deal with differnt compression, valves, and tuning of the ECU. They all are the same block but with slightly adjusted heads. Spoort Compoact did a write up way back about a Yamaha engine that is in the show. Just by replacing the valves and cams they were able to make that puppy scream to 10,000 RPM's with no problems. Wish we had DOHC though.
Old Feb 12, 2002
SatinSilver2k1's Avatar
SatinSilver2k1 is an unknown quantity at this point
two of my freinds have EL's and i've revved right beside them and they sound the exact same..same engine...same HP...
Old Feb 12, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
D17A2 is the 2k1 EX's code. check the el block to see if their the same.
mikemc422
Aug 9, 2018 05:41 PM
Wild Cranker
May 19, 2015 06:10 PM
cloudguy
Apr 28, 2015 05:02 AM
Cross
Jan 6, 2002 01:31 AM
TaiChi
Dec 17, 2001 09:09 PM
