trunk lever
Old Nov 2, 2005
slinger412's Avatar
slinger412 is an unknown quantity at this point
trunk lever
The lever on the floor to the left of the driver's seat on my 2002 LX seem to be stuck. It allows me to open the gas tank but not the trunk. I think i can fix it if i could get access to under it's plastic cover. Any idea on how to do that without recking anything or anyways to fix it?
Thanks
Old Nov 2, 2005
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
Hey man, Ok first did you lock it? If not you need to pull the plastic panel off where gas/trunck lever sit, the lock barrel will come off but the lever. Once you have it off you'll see a crescent shaped wheel down inside. Assuming that you're looking down at this from the left side of driver seat, twist the little wheel to the left, it should and click and you should be able to pull up and truck lever. Hope this helps
Old Nov 2, 2005
CraigW's Avatar
The covers are just clipped in, easy to remove. Someone on here provided this as well http://www.geocities.com/pfeifferper...oesNotWork.pdf
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
Skunkone
Sep 24, 2015 04:38 PM
