Which is a better buy?
Old Oct 26, 2005
Ryan2005's Avatar
Ryan2005 is an unknown quantity at this point
whats up guys, i'm going to be buying a bike pretty soon and i have narrowed my choices down to the honda cbr600rr and the suzuki gsx-r600. this will be my first bike, please feel free to give good and bad opinions on these bikes, i really would like to know what you guys think. thanks
Old Oct 26, 2005
Ryan2005's Avatar
here are the specs in case you guys want to know
honda cbr600rr
Engine Type 599cc liquid-cooled inline four-cylinder
Bore and Stroke 67.0mm x 42.5mm
Compression Ratio 12.0:1
Valve Train DOHC; four valves per cylinder
Carburetion Dual Stage Fuel Injection (DSFI)
Ignition Computer-controlled digital transistorized with three-dimensional mapping
DRIVE TRAIN
Transmission Close-ratio six-speed
Final Drive #525 O-ring-sealed chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension 41.0mm inverted HMAS cartridge fork with spring-preload, rebound and compression-damping adjustability; 4.7-inch travel
Rear Suspension Unit Pro-Link HMAS single shock with spring-preload, rebound and compression-damping adjustability; 5.1-inch travel
Front Brakes Dual radial-mounted four-piston calipers with 310.0mm discs
Rear Brake Single 220.0mm disc
Front Tire 120/70ZR-17 radial
Rear Tire 180/55ZR-17 radial
DIMENSIONS
Rake 24.0 degrees
Trail 95.0mm (3.7 inches)
Wheelbase 54.7 inches
Seat Height 32.3 inches
Turning Radius 10.5 feet
Dry Weight 361 pounds
Fuel Capacity 4.8 gallons, including 0.9-gallon reserve
OTHER
Available Colors Black, Pearl Orange/Black Tribal, Light Silver Metallic, Red/Black
Model ID CBR600RR
FACTORY WARRANTY INFORMATION
1 year Transferable, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
and now the gsx-r600
Engine: 599cc,4-stroke,four-cylinder, liquid-cooled, DOHC, 16-valve
Bore Stroke: 67.0 x 42.5mm
Compression Ratio: 12.5:1
Fuel System: Fuel Injection
Lubrication: Wet Sump
Ignition: Digital/transistorized
Transmission: 6-speed, constant mesh
Final Drive: #525 chain
Overall Length: 2040mm (80.3 in.)
Overall Width: 715mm (28.1 in.)
Overall Height: 1125mm 44.7 in.)
Seat Height: 810mm (31.9 in.)
Ground Clearance: TBD
Wheelbase: 1400mm (55.1 in.)
Dry Weight: 161kg (354 lbs)
Suspension Front: Cartridge-type, coil spring, fully adjustable spring preload, rebound and compression damping
Suspension Rear: Link-type, gas/oil damped, fully adjustable spring preload, compression and rebound damping
Brakes Front: Dual hydraulic disc
Brakes Rear: Single hydraulic disc
Tires Front: 120/70-ZR-17
Tires Rear: 180/55-ZR-17
Fuel Tank Capacity: 17 liter (4.5 gal.)
Color: White/Blue, Red/Black, Black/Gray, Silver/White
Old Oct 26, 2005
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
everyone will tell you to get the gixxer, and its a nice bike, comes fairly well modified stock, it has a steering stablilizer and all and it handles okay, but the 600RR is a sweet bike. I personally have a F4i, and im going to upgrade to a repsol 1000rr in the spring, but with the honda you get honda quality, im not to sure about the suzuki quality. Theres talk on the bike forums about the suzuki frames cracking at the welds and stuff like that. Kinda scary, id say get the 600rr
Old Oct 26, 2005
dp_yz713's Avatar
Boobies are the mans tinkertoys
dp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to beholddp_yz713 is a splendid one to behold
I myself would chose the r6. i got one and i love it. handles well and accelerates hard!! out of your choices go with the 600rr, exhaust under the seat looks tight.!
Old Oct 26, 2005
jzuha01's Avatar
Championship White 04 Ex Coupe
jzuha01 is an unknown quantity at this point
I test drove both of those bikes before I purchased my gsx-r 600. It really all comes down to which bike you feel more comfortable on. I just felt more comfortable on the gsx-r. When I bought my bike it was named sportbike of the year in 04.
Old Oct 26, 2005
dre2600's Avatar
Get a CBR600F4i if its your first bike, the GSX-R is way too light and squirrely in the front end and if you don't know what you're doing that can get you into trouble really quickly. The RR stands for 'race replica', if its your first bike, opt for the F4i, -much- more forgiving. Barring that, maybe an older 900 cc would be good, less of a jerky 600cc powerband that can catch you off guard.
Old Oct 27, 2005
those reasons you mentioned are the only reason why i bought an F4i as my first bike. Ive ridden it about 15,000 miles and prolly gonna pick up a repsol 1000rr in the spring. I have friends that bought gixxers as their first bikes and have dumped them doin the twisties... R6 is the same way... stick with the honda though... remember it may look good when its new, but if you dont know how to ride it, and you drop it, its not gonna look to good!
Old Oct 27, 2005
R1Style's Avatar
Honestly, both bikes are nearly identical in terms of performance and weight. There's no point in even looking at the specs of the bike. Quality of the bikes will also be roughly the same.
I say go to your local bike shop and sit on both bikes...even better, go sit on all the 600's. Buy whatever you're most comfortable on, fits you best or what you think is the best looking bike. For a beginner, hp/tq numbers and handling characteristics means ****...
Good luck be careful and happy riding
Old Oct 27, 2005
dre2600's Avatar
Yeah, those bikes are more track-oriented than the F4i, thats the very reason Honda released the RR, because it was having a tough problem justifying to people why they should buy the F4i if they're going to track it w.out having to mod it a bit first. I'll be taking possession today of a '98 CBR900RR as my first bike, its got relaxed ergos and a linear, predictable powerband. More displacement isn't always bad, it can even be good for a beginner (less shifting, esp. in corners for example, power on demand, linear powerband) unless they're crazy and try doing wheelies all the time.
Old Oct 27, 2005
Ryan2005's Avatar
thanks for all the advise, too bad i will have to wait until the end of next month before i can go and sit on 'em. both the honda and suzuki places are out of stock of both and won't have the new models in until late nov.
Old Oct 28, 2005
EL-Sport's Avatar
EL-Sport is an unknown quantity at this point
If its your first bike and you are a new rider, I'd suggest picking up something used and maybe less powerful, such as a Kawi Ninja 500 or Suzuki SV650.
Old Oct 28, 2005
YUL's Avatar
YUL
YUL has a spectacular aura aboutYUL has a spectacular aura about
^^ totally agree. I think you should consider a used bike (non sport) and ride it for 1 season then trade up to a new bike once you get your skills developed.
You're only 19 dude...Kind of risky to ride a new 600 sport bike. what will your insurance be like?
Old Oct 28, 2005
xkimsungminx's Avatar
xkimsungminx is an unknown quantity at this point
yea you should go with a used bike, and whatever you do dont give your friends rides on your bike until after you've gotten lots of ride time and experience with your bike so you know how it handles and stuff, -_-;; unlike someone i know, i got tossed of an R6 while we were riding down the twisty parts of sunset blvd and i almost got my right leg taken out, my right knee cap almost broke in half and my skin ripped apart so YEA it's pretty dangerous haha, sucks for me, but good warning for you i guess.
Old Oct 28, 2005
oh and it's been about 9 months since the accident and i still have no nerve connection on my right knee cuz of the way my skin got torn apart, and i think it's still puffy around and below the knee cap and it's still bruised underneath the knee cap so, no snowboarding for me this season -_-;; EFF!
Old Oct 29, 2005
usafstud's Avatar
buddy, if this is ur first bike, either one would be fast or good enough
i would go with the 600rr
Old Oct 30, 2005
ddevil0013's Avatar
You gotta be as blind as Anne Frank not to see that
ddevil0013 is on a distinguished road
+1
I started on a 01 R6 actually still have it but selling it now. Do not get a new bike as your first. Definetely go with a kawi 250 or 500,suzuki gs500 or some of the older 600's like honda f2 or 3.
As much as i love my R6 i would not have gotten it as my first bike. It is very fast very light and things can get crazy in a hurry. Im also 19 and i think of myself as pretty responsible but once you get on it and you get going it is soooooo tempting to rip the throttle open and you can get careless pretty easy. Starting off small will make you a much better rider later on.
And I was quoted 6K/year for full insurance (which I would recommend to anyone with a bike) my bike only cost me 5K lol so there's no way I will pay that much insurance. Oh and def take the MSF and read these:
http://forums.sportbikes.net/forums/...d.php?t=262785
http://forums.sportbikes.net/forums/...d.php?t=274759
good luck in whatever you choose
Old Oct 30, 2005
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
Okay I didn't read the whole thread but I've been riding for quite some time, and I swear by gixxers.
HOWEVER, if this is your first bike DO NOT get a gixxer. It's not a beginner's bike. The CBR is more a bike for the masses. It's more user friendly, and has a much easier riding stance. Easier on your whole body, and more comfortable. With a gixxer you're riding in a constant forced tuck, and the gixxer is more fidgety...one quick flick of your elbows and your bike will be in the dirt. The Honda is more forgiving.
Get the Honda...
Old Oct 30, 2005
Ryan2005's Avatar
i had thought about getting a ninja 250 (one reason being they are so much cheaper) and the fact like you guys said that it is smaller. the insurance isn't bad on either bike for me, i was quoted like 75$/month with full coverage, thats alot cheaper than what i am paying for my civic.
i had also thought about getting a used bike but alot of people tell me that buying a used bike isn't that good of an idea because you dont know how the owner drove it, which is the same thing with cars but i know alot more about cars than what i do bikes, is there anything to look for when buying a used bike that might tell how the bike has been taken care of?
Old Oct 30, 2005
ddevil0013's Avatar
http://www.clarity.net/~adam/buying-bike.html
Old Oct 30, 2005
thegent's Avatar
thegent is an unknown quantity at this point
Originally Posted by nookiemonster
Get the Honda...
I imagine you saying it in a low voice, with big convincing eyes, almost trying to brainwash the person.
Geeet the Hondaaaa
juror
Suspension DIY
Jul 30, 2019 03:28 AM
viperGTS
Jul 27, 2015 08:40 PM
viperGTS
Jul 27, 2015 08:38 PM
srtlat
Jul 17, 2015 11:53 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
