S2000 facts
Old Nov 19, 2009
  #91
Re: S2000 facts
lol funny you should say that. our 92 miata has had one problem its whole life, and that was the clutch slipping. all our hondas (and acura) have had 10+ problems, and mine is only 8 yrs old. i would take the mazda anyday over a honda.
here lets see
92 miata
-clutch
92 accord
-master cylinder failed
-distributor/timing problems (almost killed the motor)
-windows and door locks seldom work
-exhaust rusted away to nothing
-transaxle is leaking tranny fluid
-major oil leaks from multiple engine seals failing
-water pump failed
-rod knock with only 90k miles! wtf
-burns oil and coolant
-shifter sometimes will not go into gear
02 civic
-alternator died after 2 yrs
-headgasket blew (still burns some coolant)
-auto trans started slipping at 50k
-driver door lock broke
-sunvisors broke
-02 sensors died prematurely
-car body has rust already
-front engine mount failed
-lca bushings crumbled
-rear endlink snapped
-washer pump died
-batteries never last more than 2 yrs
-ebrake barely works
-vtec solenoid failed
-iac and throttle body issues
-rear main seal leaking
03 rsx
-ps pump failed after 3 yrs
-both door lock actuators failed
-temp sensor failed
-sportronic trans has issues shifting
-sunroof doesnt always work
i could go on all day but i dont feel like spending time thinking about it.
Zygrene
Mar 22, 2016 12:36 PM
Nalmonte
Sep 28, 2015 01:10 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
charmon4815
General
Sep 22, 2015 08:00 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
