Quick question: whp vs hp?
Old Jun 6, 2005
Sko's Avatar
Sko
Sko is an unknown quantity at this point
Whats the differance, and why does it matter?
I've done some searches on howstuffworks.com but haven't see anything...
Thanks
Old Jun 6, 2005
Stachmo's Avatar
"You leave me in the trenches taking Grenades, John"
Stachmo is an unknown quantity at this point
hp is what your engine puts out
whp is how much of that power actually makes it to the wheels (i.e. what you are actually putting to use)
hp will always be higher because you lose I think like 20-30% (depending upon the car) from when the engine makes it, to when it gets to the wheels
Old Jun 6, 2005
Stachmo's Avatar
for example...
a 7thgen civic ex stock makes 127hp...in actuallity (sp?) it puts about 100whp (I think) to the wheels
edit: by the way... hp=horsepower whp=wheel horsepower just in case you didnt know
Old Jun 6, 2005
QBoi's Avatar
Originally Posted by Stachmo
for example...
the 5 speed ex makes about 100 to the wheels. the auto makes a bit less
Old Jun 6, 2005
jonnyg's Avatar
E36 M3 Driver.
jonnyg is an unknown quantity at this point
another point, the power is lost through the transmission.
Old Jun 6, 2005
Got Boost???'s Avatar
flywheel horsepower is the amount of power an engine makes at the flywheel. This is typically the number manufacturers advirtise.
However an engine by itself isn't going anywhere. It needs tires, brakes, rims, axels, and a transimission to get around town. All of these parts spin, and it takes power to spin these parts. So a portion of the engines power is used to spin these other parts. Soooo by the time your finally getting power to the wheels, you will have lost a fraction of your engines power.
But you can reduce the amount power lost in the drivetrain. By getting average sized lightweight rims it takes less power to spin them so more power gets put to the ground. For FWD cars lighter rims and brakes are about the only thing you can do. But for RWD and AWD cars you can get lightweight driveshafts as well. Automatic transmissions also eat up alot of power.
Heres a general overview
FWD manual - 12% loss
RWD manual - 15% loss
FWD auto - 17% loss
RWD auto - 20% loss
AWD manual - 22% loss
AWD auto - 27% loss
Old Jun 7, 2005
S2000man01's Avatar
O RLY
just an FYI also. you can never say it's going to be exactly a certain percentage. he's giving you a general idea.
and in fact, it's not even the same percentage with the same car. it's dependent on several different factors, and on different days/situations, the same car may suffer more or less power loss from the engine to the wheels.
Old Jun 7, 2005
jttegx's Avatar
OMNES AD UNUM
good post, got boost, i never knew any of that. maybe someone can sticky this for awhile til it gets lame. im sure i wasnt the only who didnt knew about the powerloss of drivetrains and whatnot.
Old Jun 7, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
um, the ex manual gets like 110 to the wheels
Old Jun 7, 2005
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
yep
the 6th gen civic ex puts out about 100whp.
Interesting note, if you look at AEM's site you could find that the most whp we could gain from an AEM CAI in a 7th gen is 2hp. While the 6th gen gains 8hp. However in both generations, theres torque lost in most of the lower 50% rpm range
Old Jun 7, 2005
Stachmo's Avatar
Originally Posted by mrchowmein
yep
wait do we gain 2whp or 2hp from the aem cai?
Old Jun 7, 2005
goto K&N for more gains. aem is garbage, all they do is market their name. Everything I buy from them ends up breaking or not working right.
Old Jun 7, 2005
Big Rob's Avatar
I'm taking over!
Big Rob has a little shameless behaviour in the past
The dyno was testing whp each time, so the gain was also whp. On a side note, there has been some controversy as to whether or not aem's dynos are accurate. I however don't really care if they are or if they aren't. I have an aem v2 and I couldn't be happier. It sound like I have a monster under the hood.
Old Jun 8, 2005
mrchowmein's Avatar
2whp peak gain at 6250 rpm. so for about $320. or i guess you could loose some weight or those out some stuff from the trunk to get similar performance gains. hahaha
Old Jun 8, 2005
and lots of torque losses
Old Jun 8, 2005
mrchowmein's Avatar
Dyno charts
AEM (just posted these on another thread too)
EX
K & N
LX
EX
hp.
so yes, the k&n will get your a bit more
Tedverseti
Apr 23, 2020 01:45 PM
ricer_em2
May 11, 2016 08:09 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
metalpres
Sep 23, 2015 05:22 AM
meicalnissyen
Sep 22, 2015 06:20 PM
