Is this bad for the car?
Old Jan 8, 2002
KUNZ's Avatar
KUNZ is an unknown quantity at this point
This probably sounds stupid, but in an automatic is it bad while your driving to drop it in neutral and rev the engine then switch back to drive?
Old Jan 8, 2002
LazyDog01's Avatar
Raceway Park Track Tech.
What do u think
Old Jan 8, 2002
antidote11's Avatar
antidote11 is an unknown quantity at this point
Yes, it is bad for your car....I would break that habit ASAP.
Old Jan 8, 2002
LexBoy's Avatar
LexBoy is an unknown quantity at this point
really guy its really really bad dude
it would kill the engine dont do it anymore and if you are not doing it dont plan on starting to do it
Old Jan 8, 2002
KUNZ's Avatar
Is it just bad for the transmission? Can you rev the engine at all in neutral even if your not moving?
Old Jan 8, 2002
KUNZ's Avatar
Is there any way to show off your exhaust while your moving in an auto?
Old Jan 8, 2002
antidote11's Avatar
The best way to show off an exhaust in an auto probably would be just to gun it. Just hammer that bi*tch.
But you can roll and rev your engine in neutral, that doesn't hurt anything, it's when the engine is reved then
thrown back into gear. You definitely don't want to do that.
Old Jan 8, 2002
UncleB's Avatar
UncleB is an unknown quantity at this point
you can always just take off and leave the guy in your dust. that does a pretty good job at showing off your exhaust. hehe.
Old Jan 8, 2002
LOWBOY's Avatar
LOWBOY is an unknown quantity at this point
Yeah, its called put in in Neutral. Then press on gas pedal. The one to the right. Not only is is bad for the tranny, but its also bad for the axle and suspension.
Old Jan 8, 2002
KUNZ's Avatar
so if your driving......then you put it in neutral...then rev the engine.....let off the gas.....then put it back to drive? so when you put it into drive your not giving it gas
Old Jan 8, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
OK, imagine this. Your wheels are spinning, which spins your drive shaft which is not connected to the transmission because you are in neutral. Now, you shift into gear, with the drive shaft spinning. You are connecting two parts, both spinning at different rates. This causes excessive wear and tear of your gears. Now, if you just rev it while you are not moving and wait fot the RPM's to drop to normal idle speed before you shift to drive, then there is no problem. Peace...
Old Jan 8, 2002
HaRdKoRePinoYrAcer's Avatar
HaRdKoRePinoYrAcer is an unknown quantity at this point
well its ok while u rev...but wait till it idles...then put it back in drive....b/c if u put it back at a high rpm ur gonna hurt the car...
Old Jan 8, 2002
01CivicMike's Avatar
01CivicMike is an unknown quantity at this point
Uh, Ya....... Dont slam it back into gear until the revs come down. Its about the same as a neutral drop - reserved for rental cars.
Mike
Old Jan 8, 2002
mikalem's Avatar
mikalem is on a distinguished road
Usually you will cause problems with the tranny if you drop it to N floor it and imediately put it back in drive, but if you MUST do it, after you rev the engine wait til the rpms travel down to where they are suposed to be normally (usually between 2 and 3 grand) before switching back to drive, causes less of a shock.
Old Jan 8, 2002
antidote11's Avatar
Just don't do it at all man...if you want to show off your exhaust, so like I said....floor that bad boy !!
Driving Off Fast: Good way to show off Intakes, headers, exhausts, wheels, Altezzas, and rear window tint : )
Old Jan 8, 2002
KUNZ's Avatar
so if your coming to a stop anyways it won't hurt the car to put it in Neutral rev it and then brake to a stop?
Old Jan 8, 2002
Swifty's Avatar
From: Ricemond B.C. Canada, British Columbia, Canada
Swifty is an unknown quantity at this point
This is a good thing to do...do it all the time.....and your transmission mechanic will love you[IMG]i/expressions/moon.gif[/IMG]
Old Jan 8, 2002
antidote11's Avatar
Yes, you can do that....you just don't want your RPMs to be above idle when you put the car back in drive. You can sit there all day and rev if you want, just don't throw it into gear when the engine is above idle in RPMs.
Old Jan 8, 2002
BlueIce2001's Avatar
BlueIce2001 is an unknown quantity at this point
just gunn it while ur in gear F!@# the other people just take off and leave em
Old Jan 8, 2002
antidote11's Avatar
Yeh, pour gas on your hood and flick matches at it : )
Old Jan 8, 2002
Toad's Avatar
Toad is an unknown quantity at this point
I have a friend that neutral drops his car a lot and it never seems to hurt the car. But I would never do it... Just rev the engine when you are coasting or stopped. Put it back into drive when the RPM drops back down below 2k
dragonsblood
Apr 27, 2015 12:28 PM
Fastfebur
Apr 26, 2015 11:57 PM
tattedlariat
Apr 20, 2015 09:26 PM
GH04si
Apr 15, 2015 08:13 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
