89 honda civic problems
Old Mar 28, 2005
msabrown's Avatar
msabrown is an unknown quantity at this point
Talking 89 honda civic problems
Hi, hope someone can help me understand my problem. I have a 89 honda civic and while driving it shut off and will not start it will turn over but will not stay started and it looses power I was told that my pistons have gone bad then I was told the timing is off, because the wrong spark plugs were installed (bosch plugs) caused the timing to be offset. The belt is loose what could the problem be? Thank you in advance for your help!
Old Mar 28, 2005
Axxe's Avatar
Axxe is an unknown quantity at this point
Check the timing belt. Spark plugs don't affect timing. Do it soon, or you'll wreck you motor.
Old Mar 28, 2005
MyK's Avatar
MyK
MyK has a little shameless behaviour in the past
does it die like its being suffocated??
could be a falty 02 sensor or a clogged catty
i dunno its hard to diagnose over the net
Old Mar 28, 2005
teampointless's Avatar
Ultimate Member
Sentences own you.
Old Mar 28, 2005
ASD CiViC's Avatar
ASD CiViC is an unknown quantity at this point
I had one of those civics check the distributor they usually give problems u should be able to get a used one from any wreckers for about $75 and a refurbished one for bout $200
Civicman92296
Apr 23, 2015 09:22 PM
jessicakaybby
Apr 20, 2015 12:11 PM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
