why it is good to redline/push your car every so often
Old Feb 6, 2005
S2000man01's Avatar
O RLY
Redlining or pushing your engine every so often is actually good for it. A byproduct of the combustion that occurs in your cylinders is carbon. After a while this carbon can build up on cylinder walls and other parts. If you never accelerate quickly, and never push your car, the carbon will continue to build up, and eventually could cause problems. Even to an extent of engine damage, such as unseating the piston rings. (this actually is a somewhat common thing on the northstar engines, and there is a TSB for it)
When you push/redline the car, this helps clear out those carbon deposits and remove the buildup inside the cylinder chamber.
Old Feb 6, 2005
i8dabomb's Avatar
I love to suck t3h c0ck & am supr ghey
i8dabomb is just really nicei8dabomb is just really nicei8dabomb is just really nicei8dabomb is just really nice
ha...all my friends are like you're gonna kill your engine redlining... that'll show em
Old Feb 6, 2005
hotrodcivic2004's Avatar
my civic has no boost
thats how i drive anyways. haha sweet.
Old Feb 6, 2005
Transformer_Guy's Avatar
Lost in the Matrix
Transformer_Guy is on a distinguished road
^^^ same here
Old Feb 6, 2005
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
I don't think I go a day without hitting redline...
Old Feb 6, 2005
fastcivic03's Avatar
fastcivic03 should not be trusted
interesting
Old Feb 6, 2005
cmeias's Avatar
cmeias is an unknown quantity at this point
sweet
Old Feb 6, 2005
quick silver's Avatar
472rwhp @ 7400 RPMs and 12.93 psi
quick silver has disabled reputation
Just remember that Honda specifically designed VTEC engines to be redlined. There are no ill-effects to redlining VTEC engines so long as you don't go past the redline.
Old Feb 6, 2005
scatman's Avatar
Still in the game...
o god...i can just see all these guys reading this then going out and beating the **** out of their cars haha
Old Feb 6, 2005
S2000man01's Avatar
O RLY
lol well there is a rev limiter to protect you from going over your redline.
however if you do a mechanical over-rev (ie put it into 2nd at 80mph) you're pretty much screwed.
Old Feb 6, 2005
RESIDENT ROTOR HEAD
Hey does the S2K beep when you hit redline?
Old Feb 6, 2005
Right about the rev limiter...but you are retarded if you take your care to that point. Your horsepower often drops or levels off about 500 rpms from redline so you are better off shifting beforehand. Best thing to do is have your car dyno'd and determine your shift points based on the horsepower / torque peaks.
Old Feb 6, 2005
_Viper_'s Avatar
I cant afford another set of tires man so I don't engage my Vtec cuz it burns my tires
Old Feb 6, 2005
joescivic02's Avatar
Abercrombie and Fitch
everyone is gonna read this thread and beat the hell out of their cars now lol
Old Feb 6, 2005
Stachmo's Avatar
"You leave me in the trenches taking Grenades, John"
Stachmo is an unknown quantity at this point
How often should you be redlining your car to keep it running well according to this??
Old Feb 6, 2005
winnerpl's Avatar
winnerpl is an unknown quantity at this point
Too bad I can't even get close to redline in my auto.
Old Feb 6, 2005
Your jokin right?
Old Feb 6, 2005
QBoi's Avatar
Floor it...
Old Feb 6, 2005
That's strange. I've floored my auto and actually had to let off because it looked like it was gonna keep going after 6500rpms. But ya you need to floor the car every so often so the vtec machinery can turn on. Normal driving (under 100% throttle) won't do it.
Old Feb 6, 2005
Back off at 6500 rpms...why? You aren't at redline...
Old Feb 6, 2005
Titleist71's Avatar
DO NOT REDLINE ALOT!!!.......Simply going down the highway and accelerating to 100 mph exercise the process just as effectively. Redlining on a daily basis is bad. Do it if you wish but I strongly suggest against it.
Old Feb 6, 2005
What are your qualifications that substantiate your statement? I used to work for Honda and I have owned over 10 of them. I can tell you that redlining VTEC engines is not harmful.
Old Feb 6, 2005
where is redline on our cars exactly cause the red part on my cluster isn't visible at night. So I just let off when it's going past the blue part. I was thinking 6800.
Oh the only thing that might happen is too much redline and you'll need a valve adjustment sooner.
Old Feb 6, 2005
Don't know for sure...but your redline should be at least 7500 rpms.
Old Feb 6, 2005
QBoi's Avatar
7500??? o.O On my cluster its about 6800
Old Feb 6, 2005
I don't have an '01-04 Civic Ex so I can't tell ya for sure. But, thinking back to some of the Civic Ex's I had, the redline was over 7K. I have an '04 LX and the redline is 6800 so the redline on the EX has got to be higher.
Old Feb 6, 2005
The cluster says 6800rpms, but maybe it's a little more.
Old Feb 6, 2005
QBoi's Avatar
I have an EX gauge cluster, its less then 7k rpms, not sure how less.
Old Feb 6, 2005
That is strange. My understanding is that VTEC engines are supposed to redline higher than non-VTEC engines.
Old Feb 6, 2005
RESIDENT ROTOR HEAD
Not if you have a 9K RPM and triangles spinning under your hood...
