1996 Corolla HU install help
pull off all the climate control *****, starting from the vents pull the dash console out towards you. There are no screws you need to worry about or anything, it's just clipped on. Once you disconnect the AC button, hazard and clock, you will see the radio is held in with 4 8mm screws. Remove these and you will be able to slide the factory radio out. use the factory brackets on your new radio and reverse the procedure. done.
if your trying to install an head unit, usually when u go buy the frame support at best buy or frys, they give u instructions in the package too. each car is diff to dissemable the dash/etc. but its usually a common procedure.
ibtm to ice/electrical
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
Q-Bert
Jul 19, 2015 09:09 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
