Cam Gears and Pully System
Old Dec 30, 2004
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
i know alot about cars, learn alot, but 2 things have been bothering me, cam gears and a new pully system, How do they help the car get more horse power? never really understood it. can someone explain?
Old Dec 30, 2004
djpolanco's Avatar
djpolanco is an unknown quantity at this point
yes i will help[ u out
Old Dec 30, 2004
Michalo187's Avatar
Abortion Survivor
The pulleys are lighter and bigger, Underdrive pulleys are smaller and lighter they both help all around the power band but i noticed them more off the line. Cam gear is also lighter and you can tune it for off the line or for turbo or nitrous applications. Anything you can make lighter will help.
Old Dec 30, 2004
The weight may help a little, but that's really not what they're for. Our stock accessory pulleys are small and heavy, and aftermarket underdrive pulleys are lighter and bigger. A bigger pulley takes a longer amount of time to make one rotation than a smaller pulley. That's where underdriving comes from. So efectively, you're reducing the peak power of these accessories.
Cam gear allows you to alter cam timing if you mill/deck the cylinder head or run nitrous. It makes sure the engine will still keep good timing. This should be tuned on a dyno.
Old Dec 30, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
also, cam gears should be tuned by someone that knows what they are doing, not just basic mechanics. It's more just to retard or advance timing.
159
Jul 5, 2015 09:54 PM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
phillip
Jul 23, 2002 04:56 PM
Belle
Apr 12, 2002 08:49 AM
CivicPunker17
Nov 21, 2001 06:14 PM
