Oil Consumption
Old Dec 20, 2004
PrimerSuspect's Avatar
PrimerSuspect is an unknown quantity at this point
Oil Consumption
anyone have any problems with oil consumption? my 01 ex burned off a quart in the last 1500 miles. i change the oil every 3k and the car has 92000 on it (mostly highway).ive has a lot of tranny problems but this is the first motor issue ive had with it since i bought it last year.
Old Dec 20, 2004
dalaw's Avatar
Bone Stock!
i have an 03 with 20k miles and my oil level doesnt move that much between oil changes. But given that your car has a lot of miles, the oil consumption could be normal.
Old Dec 20, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
A quart in 1500 would worry me. If you bought it used, I'd get the compression checked and see if maybe a ring went bad or something. It shouldn't be doing that.
I take it you've already looked around for leaks?
Old Dec 20, 2004
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
i burn a quart every 2 weeks or so, turbo is leakin like a beouch!!!!
Old Dec 20, 2004
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
I have to add a little oil prolly once in between oil changes, but a whole quart in 1500 miles seems like a lot to me. I'd check the plugs...
Old Dec 21, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
It's likely an exterior leak (you'd see that), worn rings, or worn valve seals. Try a slightly thicker oil.
Old Dec 21, 2004
If he drives it hard as hell all the time then it could be normal, but I doubt it. A whole quart every 1,500 miles is a lot of oil for our engines... If he chooses to go with a slightly thicker oil I wouldnt go with anything heavier than 5w-30. If it turns out to be an exterior leak it would be easy to tell unless somebody didnt tighten the the oil filter good enough. That happened once to me.
Old Dec 21, 2004
JP375's Avatar
JP375 is an unknown quantity at this point
Seems a bit much. I'd check with the techs at a dealership and see what they say. Some cars such as BMW's consume about that much oil, and are still well within spec. You could still be within reasonable limits even with a quart every 1500 miles. Having said that, I've never known a Honda engine to burn a single drop, even with high mileage. If I was you I would get it checked out.
Old Dec 21, 2004
Everything you said right there seems VERY logical however, I disagree with your belief that no normal honda engine that you've ever heard of has ever burned oil. I've heard of hondas burning a lil oil...I've been hearing that for a while...
Old Dec 21, 2004
Also, I believe that if you check the owners manual, honda recommends that the oil level in your car be checked every time you fill up with gas. I believe there is a reason for this recommendation other than "just playing it safe".
Old Dec 21, 2004
Gangsta Dave's Avatar
People Eating Tasty Animals PETA
Gangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to allGangsta Dave is a name known to all
I have 82,000 miles on my 2k1 civic lx and it never has burned oil like that. NOt once have I ever had to add oil. go get it checked out!
Old Dec 21, 2004
Some people like myself like to keep it topped off which is why I say I have to add a lil oil maybe once between every oil change. Everyones oil consumption is going to vary depending on their driving habbits as well I think. I drive my car hard as fvck probably more than a 1/3 of the time and thats not including the use of my bottle occasionally.
Old Dec 21, 2004
solar's Avatar
solar is an unknown quantity at this point
I would heed Boilermaker1 advice, compression check and leak check is a very good place to start. My K20A3 in my 03 Si used about a quart of oil in the first 5,000 miles when it was new, but it stopped after the second oil change.
Old Dec 22, 2004
i am a tech at ford so i keep up on my maintenance.it did it once before and scared the **** out of me cuz the check engine light came on and it woulndnt go past 4000 rpm. turns out it was the vtec not getting oil. since then ive checked up on it constantly and that was only 5000 miles ago. i compression checked it over the summer and everything was fine. it has no leaks (that was the first thing i checked). if its internal im just gonna take a hit between what i owe and what i gat and get rid of it. i just hope it lasts til my hearing against honda in march.
Old Dec 22, 2004
Jap-Euro Fusion
On heavily tracked cars, you'll see people overfill the oil by as much as a quart, not because the car is burning it, but because the VTEC system tends to consume a little and it becomes very irritated when there isn't enough for it. That and the design of the oil pan can sometimes pull the oil off the pickup in hard left hand turns (K-series its probably right handers).
Old Dec 23, 2004
exclusive_vtec's Avatar
same ^ id check em
Old Dec 23, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
no consumption here. '03 ex
Old Dec 23, 2004
good for you!
Old Dec 23, 2004
ctx66's Avatar
he asked if anyone had consumption, and i replied.
Old Dec 23, 2004
that doesnt help him. and besides you're either really easy on your car all time when you drive it or you arent paying close enough attention to notice the difference in your oil levels when checking your oil level. I think all hondas use a little oil, even if its just a little.
Old Dec 23, 2004
SIinthesky's Avatar
SIinthesky will become famous soon enoughSIinthesky will become famous soon enough
See if its leaking from the crush washer that is supposed to be around the drain plug. If your getting a little blue smoke from the tailpipe it could be a head gasket or ring problem. Maybe spark plug grommets. Do a close inspection and look for oil anywhere on the engine. Let us know what you find out.
Old Dec 23, 2004
ctx66's Avatar
no, im not a moron. my car does not consume any oil. driving style is 80% conservative 20% hard.
Old Dec 23, 2004
the bottom of the car is dry. completely dry.i havent noticed any smoke and it doesnt smell like oil burning. thats the whole problem. i know what to look for, im just not finding anything.i havent really been beating on it besides occasionally taching out first to chirp second. the only place i havent checked out really well is the coolant. but i think i would notice that much oil if it was in the coolant.
Old Dec 23, 2004
^^You checked all the plugs and nothing looks out of the ordinary there? If any look brown at all compared to the others that could be a sign.
Old Dec 23, 2004
Oh and you dont necessarily have to see any smoke to have oil burning.
Old Dec 23, 2004
i know that but for the amount that got burned in such little time? i checked my plugs about 8k ago and replaced the valve cover gaskets and oil control rings when i adjusted my valves at the same time.
Old Dec 23, 2004
check your plugs again
Old Dec 23, 2004
SIinthesky's Avatar
Time to get scooby-doo because this is a mystery.
brags
46
Jan 7, 2016 09:39 PM
emich
Dec 11, 2015 12:20 PM
SidCivic
17
Aug 23, 2015 03:14 AM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
