N/A for 1999 civic si
Old Dec 9, 2004
taffeta_RSX's Avatar
taffeta_RSX is an unknown quantity at this point
Ok i have a friend that says he will put down 225whp with his civic 1999 si , with it/h/e ECU , and build his hi end of the motor. also hes not gonna strip interior. i told him there was no way he would get that amount of whp going n/a , but this guy is absolutly serious he can do it. , and im not a expert on the b16 engine , but i really doubt it can be done going n/a. am i right ? or can my friend have hopes , and dreams only?
Old Dec 9, 2004
acurastype01's Avatar
w00t
acurastype01 is an unknown quantity at this point
you like posting twice?
Old Dec 9, 2004
sw388integra's Avatar
toda ITB's are dynoed (properly tuned, mind you) to 40 hp! i'm running a b20z with a b16 head in my crx and only putting down 217 to the wheels, but torque is 158 ft. lbs.!
but anyway, cams ported head, higher comp. pistons and ITB's, he might be able to pull 225 hp.....?....
Old Dec 9, 2004
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
ull easily pull off 225whp with a b16 n/a, if u know what ur doing. but did ur friend say that he could do it with just intake/header/exhaust and ECU? or 225WHP with the built top end too?
Old Dec 9, 2004
Drakkar's Avatar
Drakkar is an unknown quantity at this point
bore and stroker kit, cams, pistons, valve job, ported head, intake manifold. he might be able to pull it off. See he probally can take it up there but the engine's life with suffer everything is a trade off.
Old Dec 9, 2004
by the way, what does stripping the interior have to do with horsepower?...
Old Dec 9, 2004
^ u wont need a bore/stroker kit and no the engines life wouldnt suffer. get a type-r intake manifold, a good header/exhaust combo, new cams, ECU mod, ported head, and maybe higher compression pistons.
Old Dec 9, 2004
Drakkar's Avatar
actually if u bore and stoke it it will affect the engine life because the wear and tear on the engine is increase and the amount of metal in the cylinders has been reduced which would affect the engine life
Old Dec 9, 2004
dre2600's Avatar
If you consider nitrous NA, then sure.
If he did get it up to 225WHP (~250hp @ the crank) he'd have a camshaft so extreme he wouldn't be able to make the damn thing idle below 4000rpm.
Old Dec 9, 2004
right, but im saying u dont have to bore/stroke it.
Old Dec 9, 2004
actually stroking it makes it stronger...but you're right to a certain to a point, it depends on how good the build is and how they use the power...
Old Dec 9, 2004
Drakkar's Avatar
the engine life thing is mainly the boreing... strokeing can affect it but if done properly it wouldn't really make a diff
Old Dec 9, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
with the right equipment and money, b16a2's (99-00 si) can pull 200+ horses going n/a. that was a serious civic and probably the best ever that went into production in the states imo. major companies like apexi, skunk2, toda, mugen, spoon, dc etc make very good parts for that car that are power proven
Old Dec 9, 2004
CivicsRdBest's Avatar
225 easy. No doubt. It cost a bit, and there are cars that have that much power new, but yes, it is possible. Just a little more mods than originally stated.
300 NA is probably a stretch.
Old Dec 9, 2004
Got Boost???'s Avatar
Im gonna call BS on your friends claim
225 whp is possible, but it requires alot more that i/h/e and an ECU
Old Dec 9, 2004
http://importtuner.com/tech/0102it_civicsi/
i/h/e put down a whopping 152.6 whp
Old Dec 9, 2004
02ciVike's Avatar
02ciVike is an unknown quantity at this point
Wow a whopping 11.5 hp with all those mods.
Old Dec 9, 2004
Arith's Avatar
Arith has a little shameless behaviour in the past
Exclamation
tell me about it.
Hmm, I think its probably possible but waaaaaaay to much cash to throw down, might aswell save it up and go turbo.
Look at it like this, he wants 225whp, the sI in stock forum dyno's about 135whp, so he's gonna need atleast 90whp. He got 12whp total from I/H/E. Now he needs 78whp going N/A... he'll need alot of internal work done, and even than... it might be a lil far featched. Tell ya friends he's throwing away alot of money...
Old Dec 9, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
hmm, if he ran race gas with a compression of 14:1 its soo possible.
Old Dec 9, 2004
exclusive_vtec's Avatar
no way he's goin to achieve that with N/A set up on a b16.. i have never seen it done at least with a b16..
Old Dec 9, 2004
D17thgen's Avatar
11hp would be nice to have. if i knew i would get that much hp, then i'd invest into some header, cat, and exhaust
Old Dec 10, 2004
Thanks for your guys reply's he did say he was gonna build the top end , and leave the bottom end alone. also he said something about having a intake throttle? i also doubt the 225whp i told him he might get 200whp that more realistic , but who knows
Old Dec 10, 2004
yes , but he said something other than intake. something about single intake throttle body. i forgot the name of that mod
Old Dec 10, 2004
individual throttle body?
Old Dec 10, 2004
dalaw's Avatar
Bone Stock!
i think the only possible way to do get 225 hp NA is to dump a huge amount of money to build up the internals, increase the compression a lot, fully rework of the valve springs, camshafts, lubrication, so that you can bring the redline and peak power up to over 10,000 rpm. By then the engine would not be very streetable. Anyway I was just thinking about Takumi's 11k rpm engine.
Old Dec 10, 2004
nindoo's Avatar
Why is my vagina bleeding?
He says that he built the high end of the motor. Could that mean he changed something like cams, or head or maybe got a regrind or something.
Someone metioned individual throttle bodies. On those old american muscle cars with carburated engines they had these huge things sticking out the hoods with the cylindrical pipes, are those the ITB's? Is it difficult to have our fuel injected d17a2 with ITBs? Will the car idle the same, will it be just as easy to drive in the street? I heard it is the best way to expose a lot of power form NA cars.
Old Dec 10, 2004
incubus7d's Avatar
I Wanna Die Like God on the Cover of Time!
incubus7d is an unknown quantity at this point
I have a 2000 Si its possible, some money is involved but definetly possible!!!
Old Dec 10, 2004
ok well guys tanks for the replys the reson for these questions is he think he can take my 2004 5-speed rsx TURBO stage 1 , putting out 250whp at 8psi
i guess we will find out , and see . i told him it was easier to put out those #'s going turbo , but hes those guys that like it the hard way of doing things no offence to the n/a guys.
usajags84
15
Aug 19, 2015 03:12 AM
usajags84
May 10, 2015 08:11 AM
aultman1990
Apr 19, 2015 07:14 AM
Cilvic
Nov 15, 2001 04:54 PM
WeRkX
Nov 1, 2001 10:33 PM
