Gas Mileage..
Old Nov 29, 2004
Mischieflts's Avatar
Mischieflts is an unknown quantity at this point
Gas Mileage..
I have a few questions about getting better gas mileage, because I think my civic might be getting less than 32/34 mpg substancially and it just seems like my car wasn't as fast and jumpy as it used to be, when it came off the lot. What could i do, that would help me increase my gas mileage? or what else could i do that might help put that new car "pick-up" in my used car?
Old Nov 29, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Check the air pressure in your tires. Never expect the milage on the EPA sticker for any car. With the exception being the Prius, it just doesn't heppen.
Old Nov 29, 2004
whyrice's Avatar
whyrice is an unknown quantity at this point
fuel injection cleaner/chevron gas.
Old Nov 29, 2004
with all common sense out of the way, what are some other ways to get better gas mileage. my tires are always at 35psi, i make sure of it. And i don't think chevron gas will give me better mileage or help my car regain it's original lost pickup.
Old Nov 29, 2004
gh0st's Avatar
TAQUITOS!!!!
my philosophy professor claims he worked for chevron and that techron does **** for engines.
Old Nov 29, 2004
dalaw's Avatar
Bone Stock!
it really depends on how you drive. every bump on the road, the distance you drive, the weather, the weight your car carries, and little stuff like that all affects your fuel mileage.
Old Nov 29, 2004
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
i honestly feel a difference when i use mobil 1 synthetic oil over generic oil. car just feels better. i always use mobil gas. keep tires inflated.
i got 39.5 mpg about a month ago. i don't know how lol.
Old Nov 29, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
^^^ 39 mpg? crazy stuff....i cant even reach 30 mpg anymore with my heavy rims
Old Nov 29, 2004
Arith's Avatar
Arith has a little shameless behaviour in the past
you honda guys are lucky, im lucky to even get 20mpg city driving or 25mpg on the highway.
Old Nov 29, 2004
ty.barrack's Avatar
ty.barrack is an unknown quantity at this point
my cicic is a 2004 and I average about 35 MPG I usually keep it at the speed limit, and don't usually drive more than 20 miles per trip. I usually let the car warm up for 3-5 minutes before driving, unless I'm Late. I accelerate fast, but usually drive at the posted limt, I have driven faster, and that's when the mileage drops significantly.
Old Nov 30, 2004
VietScouty's Avatar
VietScouty is an unknown quantity at this point
Keep driving on freeways!!! It helps because I had maxed out 400/tank with only 2 gallons left in the tank and it depends the weight within your car etc, if you're going to go for 18's which weighs about 20 lbs, I recommend that you should get CF or racing front seats, CF hood, and fenders to even out the weight of the car. I don't really know exactly but its my theory to take off some weight when gaining some.
Old Nov 30, 2004
2K1Civic17"Gabe's Avatar
How come not one person said check your air filter??? that will cause loss in HP, and fuel mileage. That would be your best bet! If it is new, I would check your spark plugs, how many miles on your car, have you done any maintenance?
Old Nov 30, 2004
solar's Avatar
solar is an unknown quantity at this point
"Might be getting less than 32/34 mpg" my question is how much less? Unless you check your milage everytime you fill up, and drive exactly the same way, your milage will vary as much as 5 plus or minus mpg. Depending on where you live its possible that you're getting "winter gas" which gives you a bit less fuel milage. If your averaging 30 mpg or more over 5 tankfulls, then I'd say nothing is wrong with your car.
Old Dec 9, 2004
zzsupermanzz15's Avatar
zzsupermanzz15 is on a distinguished road
yea i got the same problem...i have an 2004 civic coupe, got it in march...just couple of months, but ive seen a dramatic gas mileage drop in the past 2-3 months or so. i got 10,000 miles on my car already...yea that's alot but i have changed my oil every five thousand miles. uhm... i got two 12inch sub's in the back, prob weight about 100lbs(without amp)? and i had gotten my revolution muffler tip installed about 2 months ago... i dont know why my gas mileage been getting bad... i prob average about 20 miles per gal or maybe even worst...im serious ! why am i losing my gas milage ! i want my gas mileage just to be liked it did before . oh and does tire pressure really make a big difference?
-thx
Old Dec 9, 2004
acurastype01's Avatar
w00t
acurastype01 is an unknown quantity at this point
the answer is buy a tornado
Old Dec 9, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
Old Dec 9, 2004
Grumble's Avatar
Stop f*cking with me.
Grumble is an unknown quantity at this point
-thx
I've got you topped. I bought mine in May and already put 11k on it. It has alot to do with my g/f living 4 hours away. Not to mention the fact that everywhere i need to go is at least 20 minutes away.... Ah well. I get 34mpg for the most part. My car is as stock as it was when i bought it though. I'm totally happy with it the way it is. Having those subs might have something to do with it. As for peppiness, I think mine's picked up more since i bought it. That's just me though.
Old Dec 9, 2004
CivicsRdBest's Avatar
I get around 32... Which is a little less than what I get during warmer weather, but I do mixed highway and city driving.
Keep the revs low, don't accelerate frequently, use the cruise control (if you have one), and use a fuel cleaner every once in a while. I stick one in half way between oil changes and the gas-mileage goes up by about 1 or 2 and the car responds better.
Old Dec 9, 2004
dalaw's Avatar
Bone Stock!
Yeah if you are driving on tires with like 15 psi in them then there is really a big difference in gas mileage.
Old Dec 9, 2004
hotrodcivic2004's Avatar
my civic has no boost
yeah the more bolt ons i seem to put on.....the more gas i seem to burn
Old Dec 9, 2004
thrash_273's Avatar
deploy,engage,destroy.. to fail is not an option
thrash_273 is an unknown quantity at this point
take a bath everyday and be sure to brush you teeth.
Old Dec 10, 2004
DexMan's Avatar
DexMan is an unknown quantity at this point
I been worring about this too, I just put back on the cold air intake (I also have header) full up my tank and got 310 when it was empty. Testing it this week too. Later I am going to make it back into short ram (aem two piece cold air) and test it again.
Old Dec 10, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
I get 35-40 MPG consistently, and I have probably close to 400-500 lbs of stereo equipment in my car. Tires, airpressure, air filter, oilchanges...all that makes a difference. Are you putting in regular or super gas? Make sure you are only using regular!
Old Dec 10, 2004
well uhm thx for the help, i guess. i saw one guy post that he has an cold air intake and and headers and is still geting 34mpg...don't if you fix up ur car, you lose gas mileage? huh. well, im gonna check my air pressure from my tires tommrw. don't know wat eles i can do from letting my car eating up gas dramaticly...oh and my car is weird...while driving on low gas..the light turns on but as i continue driving..the gas meter goes up a lil by lil aha weird... but still I want my car to be like it use too (where i can put 5 dallors on an empty tank and the gas meter goes up half way) ahahha....i live in la..where we get like 2 bucks a gal. shiz...sorry if it sounds like im being a lil girl about gas...but im a teenager, not to mention a broke teenager at that!
Old Dec 10, 2004
TemjinX2's Avatar
i got my 04 about a yr ago when they first came out. I started at about 28mpg, then it when up to about 30mpg. After the break in period, i just to gun it and i still got 28mpg. I drive kinda like a granny now, keep my rpm's 2k-3k and i get 33-35mpg. I got a little higher mileage when i had my aem sri in there, around 33-38mpg. This is with an auto and my car now has 30k on it.
The air filter and tire pressure can be huge factor in mpg, that everyone just mentioned. If you have a new car, i noticed my mpg kept going up until about the 10k mark. Seems like the car fully broken in at around 10k. I remember someone said that the d17's perform better once you break them in for a bit. I was getting 28mpg when my tire psi was about 28. When i inflated it to 35 i got back in the 30's again. Then again i do a lot of highway driving, i would say 80% is highway. City driving kills every cars mpg.
Old Dec 10, 2004
silver_surfer's Avatar
Pretty friggin old-school member
silver_surfer is a glorious beacon of lightsilver_surfer is a glorious beacon of lightsilver_surfer is a glorious beacon of lightsilver_surfer is a glorious beacon of lightsilver_surfer is a glorious beacon of light
I seem to get 29.5 every time now. I do have rims, and an intake. I'm sure that effects it quite a bit. I'm about to take my wheels off for the winter, hopefully that will help
Old Dec 10, 2004
scatman's Avatar
Still in the game...
damn, one time in my 01 EX i got 449 miles out of one tank and the light was on when i was driving ino the gas station......of course a lot of it was highway, but still
Old Dec 10, 2004
AHHA 449 that's a grip, yea i remember when i first got my car i drove it out of the dealership and than drove around with it for 400 miles on just one full tank. i was like "****! what kind of gas do the dealership use" ahah serious what kind do they use?! how did i get 400 on one full tank ! when i first got the car
Old Dec 10, 2004
yeah, I used to get like 4-425. I can get about 350-375 now. that is about 10 gallons though, so not too bad. I have 88,000 miles on my car, too. I had a CAI, took that off like 2 weeks ago. I only have a catback exhaust on now, and 17" rims. Also about 75lbs of stereo equip. Car is more responsive than when I bought it (or maybe I learned to shift very well) So I get between 27-36 mpg. It all depends on how hard I drive. Usually somewhere around 32 mpg. I think I need to change my stock air filter, though, should help big time.
Old Dec 10, 2004
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
during the summer i was hitting 38mpg easily. after tire rotation, oil change and tire adjustment, i got 40mpg. i got 40mpg with ac running and with the trunk full. drove for about 400 miles going 75mph. that was by far the best ive gotten. i have an ex sedan civic with auto. friend with a manual got 41mpg, but he was giong 50mph for a long time. how ever recently ive been getting 30-33mpg. im guess its the fuel mixture of winter fuel?
mistahlorax13
21
Nov 18, 2015 12:47 PM
tropicola
Sep 25, 2015 07:02 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
