Do YOU "warm" your car?
Old Mar 26, 2004
  #61
DC5@EM2's Avatar
DC5@EM2 is an unknown quantity at this point
And how long does it take for the car to get at "standard operating temperature"? Either way when you start the car and just go, your motor is STILL at a higher RPM. So, enlighten me on that.
What you want to do is get the car at standard operating temperature a lot sooner than just letting the car sit there and eventually get up to 210-220 degrees F. When you start up the car up and just drive the car normally, you will bring up the engine temperature a lot sooner thus it will start thinning out the oil in the motor, and it can get on with its lubrication and heat transfer job . In the winter time and even in the summer time, when the motor is cool, the oil tends to sludge up because the oil molecules are more compacted together. When engine heat is introduced throughout the motor, the oil molecules start to move around more and more as heat is built up. Each oil depending on what grade you are running is designed to either run in really cold weather, really warm weather or even some oils are produced for heavy heat transfer and lubrication for race applications. Yes, If you are running the right oil grade in your car for your specific climate, it will resist sludging in those extreme temperatures. But the engine still needs to thin out the motor oil so that it can penetrate those extremely tight oil galleries, passageways, and channels. Do you think thick, sludgey oil can do that? When you guys let your cars just sit there for even 10 minutes to "warm" up, its still revving really high throughout those 10 minutes and your possibily starving the engine for the right lubrication and heat transfer it needs. The reason why your engine idles a lot higher at cold start up is because the engine is trying to stay within a safe rpm range and yet trying to get engine temperatures up as soon as possible. I guarantee that if you run a car at idle for even 10 mins, the wear and tear on the motor will be more significant than one that is started up and driven with some sanity. Thats why a lot of the major car manufacturers out there give you the option to purchase the engine heater accessory for cars that are operated in locations of extreme cold conditions.
Besides, I am sure the oil needs peaks at "C" when it reaches that proper temperature... which doesn't take "10-20 minutes" whatsoever.
In order for engine lubrication and heat transfer to properly work, the oil needs to be thin enough to penetrate those tight 0.000X" areas within your rod bearings, crank bearings, oil passageways, etc. Yes you are right, if the engine temperature is brought up quicker than just idle rpms and temperatures, you can get that engine running lubed and much more safely in probably less than half the time. And yes, oil needs to be at its designed temperature for it work 100% properly.
But like I said. When I was 16 I cracked a radiator in my '94 topaz during the winter from not warming it up. I started it, waited like 1 or 2 minutes and left... then half a mile later i didn't have heat, i lost power steering, then she broke down. I know/believe that warming my car overall is much better to do in the long run. Every car I have had since I warm it considerably.
Okay, now we are dealing with something totally different. We are dealing with the coolant system of the car and that can open a big fat can of worms when dealing with cold weather. For instance, if your ethelyne glycol (anti-freeze) and water mixture were way off from a 50/50 mix, that could of killed your killed your radiator. If your thermostat was malfunctioning and stuck shut, that could pose problems in your coolant system. If you didnt do a coolant change for a long period of time, that could allow scaling (rusting) in your coolant passageways/channels and could be really devastating to a coolant system. I could go on and on with that statement. Losing P/S on the car tells me that either a belt or pulley on your topaz could of went bad and you can bet that if that were to happen, your water pump would probably fail, thus could of caused another possibility the coolant system failed. See, you cant just blame not letting your car "warm" up was the reason why your coolant system failed. Two completely different systems on the car.......
Old Mar 26, 2004
  #62
JJJ's Avatar
JJJ
JJJ is an unknown quantity at this point
by warm up the car do you mean fart in the car? cuz, yes, I do..occasionaly.
Old Mar 26, 2004
  #63
TonySTiX's Avatar
TonySTiX is an unknown quantity at this point
^lol, no dont think thats what is meant in this thread heheh
Old Mar 26, 2004
  #64
zen_master's Avatar
hm..
i usually warm up...1 to 2 minutes in winter..
less than 1 minute in summer...that's good enough for the juices to flow, i think..
just look at the clock on ur radio....let it change 1 digit...and roll ur car...
Old Mar 28, 2004
  #65
wzcb08's Avatar
wzcb08 is an unknown quantity at this point
Re: Do YOU "warm" your car?
Originally posted by AR
Do you warm your car up before you leave?
I always do, always have. Esp. these days since I don't drive my ride daily.
I think I could count the times on one hand that I was in big rush and couldn't warm my '02 sedan Even when I didn't warm it, I'd stay under like 2500 rpm until the oil temp moved passed "C".
You guys cannot tell me different! I know this is best from experience.
Best way to warm it up. Drive the car but not at a high RPM.
Old Mar 28, 2004
  #66
sihotan's Avatar
sihotan is an unknown quantity at this point
in the winter i let it warm up for about 5-7 minutes.
on warmer days i warm it up for about a minute, this allows the the engine oil to work its way through the engine and lubricate all the parts. the oils very thin anyways and it flows faster(5W20).
i remember a mechanic telling me once that when your engine warms up and your about drive you should still drive slow for the first 3-5 minutes. he said this allows your other mechanical moving parts to warm up and/ort lubricated (tranny, tires,etc)
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
ImmortalEX
Oct 31, 2001 10:00 PM
