General 6th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
What is this? Can't identify
Old Dec 3, 2021
TMikeC's Avatar
TMikeC is an unknown quantity at this point
In the center of this picture is something I cannot figure out. This is a 1997 Civic EX coupe. This thing has a single blue wire going to it and then it has a rubber sheath around it and it is attached to the body. It is not a button, the front of it does not push in and out, nothing comes in contact with it and it is isolated from ground. As far as I can figure it does not even make a complete circuit with anything. Someone has to know what this is.
Old Dec 3, 2021
BrotatoChip's Avatar
Super Moderator
Re: What is this? Can't identify
I believe I found a part number for it, it's a cap. The wire must be used on some trims (possibly overseas), but on yours it's just capped. Maybe someone else knows. Part number 91637-SF1-003.
Old Dec 3, 2021
Colin42's Avatar
Tach signal wire. Used for diagnosis/tuning and remote starter installs
Old Dec 3, 2021
TMikeC's Avatar
Tach signal wire for diagnostics?? Are you sure? Why would they do that when you can just use the OBD port, isn't that what it is for?
Old Dec 4, 2021
Colin42's Avatar
Because back in the day you didn't have fancy computerized obd scanners....
user 73921
Oct 14, 2017 03:28 PM
ralph50
Jul 20, 2010 07:55 AM
dirtySAMURAI
82
Sep 7, 2005 11:43 AM
Boosted2k2
Engine Swaps
24
Sep 30, 2004 02:32 PM
BLiTz
Aug 19, 2002 06:38 AM
