General 6th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Trying to buy another civic, but know nothing about LS VTEC. help?
Old Jul 20, 2021
SE7ENZEROTWO's Avatar
SE7ENZEROTWO is an unknown quantity at this point
I've been trying to do my research on other sites about safe rev limits, but I'm looking at a civic with a semi built LSVTEC swap.
notes from the seller:
P72-2 Head B18B Block Double springs and retainers, valve guides (spring lmas), aftermarket valves better then oem, valves been sittied, Head light port and a good polish, injectors 750cc cams been thru a balance check and polished. Oem cams gste belt. Type r aftermarket pistons There sharp domewith a small flat. Stock rods, balanced crankshaft with polish. Type r water bump, Type r oil pump Oem pully Gsr transmission had 3rd rebuilt so its smooth now Catch can was for crank pressure relieve...
He says rev limit is at 9k rpm. Would that be safe with the above considering it's a B18A block and GSR head?
Old Jul 20, 2021
FRSam's Avatar
Click Here
Re: Trying to buy another civic, but know nothing about LS VTEC. help?
The only concern I’d have with that is the stock rods. I’d upgrade them long-term to something like Eagle.
No girdle either? It’s not necessary but it’d be nice to have.
Old Jul 20, 2021
Colin42's Avatar
Personally I wouldn't buy a car that is already modified, look at the disaster that your last car was
Old Jul 20, 2021
BrotatoChip's Avatar
Super Moderator
Does it even make power at 9k? GSR rev limit is ~8k, seems like those cams wouldn't do much up at 9k.
Old Jul 20, 2021
i've decided against it. but my last civic actually started to come out ok at the end.
gonna talk to some shops and get some quotes on rebuilding things.
Chino.G
Engine Swaps
Jan 14, 2021 10:09 PM
Running Riot
Aug 14, 2012 09:07 AM
Running Riot
19
Feb 26, 2010 03:12 PM
GoOkStA
Jun 19, 2003 01:29 PM
M1kEzPr1NcEzZ
Apr 19, 2003 12:47 AM
