General 6th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
I have a question about the d15b vtec engine
Old May 17, 2021
Birge's Avatar
Pockets empty, Civic's full
Birge is an unknown quantity at this point
Question I have a question about the d15b vtec engine
I'm still a bit of a n00b when it comes to Honda engines so sorry for the dumb question(s). I am currently working with a D15B Vtec engine in my 96 civic ex. I have also just learned that there is a 3 stage vtec for the d15b. I also noticed that the 3 stage vtec have two vtec solenoids, mine only has one, assuming i have sort of a basic vtec on my engine. what are the differences? what on is better? and if I wanted to "Upgrade" (if its even worth it) to a 3 stage how would i go about doing it? Note: i do plan on boosting in the near future. I appreciate all the help and info provided.
Old May 17, 2021
FRSam's Avatar
Click Here
Re: I have a question about the d15b vtec engine
https://honda-tech.com/forums/honda-...5b-get-706819/
The 3-stage vtec heads are relatively rare (therefore expensive), so I'm not sure it would be worth the hassle.
The D15B is a great engine if you want to boost. Just make sure you have the supporting mods if you want more than like 150whp.
Old May 17, 2021
Birge's Avatar
Thanks for the info? now say i ended up finding one for a good price, would it fit right onto my current one minus the wiring and possible ecu? (Assuming it runs on a different one) ill probably end up scratching that idea but just in case haha
Old May 17, 2021
FRSam's Avatar
Click Here
It'll bolt up. ECU and wiring will change, like you mentioned.
Old May 17, 2021
Birge's Avatar
Copy that sounds good, I appreciate your time and help, alot
Old May 17, 2021
FRSam's Avatar
Click Here
No problem, happy to help
brta
Aug 16, 2017 01:18 AM
sdaidoji
Jan 25, 2014 11:42 AM
ksteak
Oct 15, 2008 03:03 PM
marcdel
Apr 21, 2005 11:24 AM
Pibe54
19
Apr 18, 2004 09:19 PM
