General 6th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
How to disconnect horn & find repalcement?
Old Oct 31, 2020
Vepy's Avatar
Noobie
Vepy is an unknown quantity at this point
I was wondering how you would unplug the stock horn on a 2000 Honda Civic Ex. I want to replace it with a lower/louder horn than the stock one, any suggestions?
Old Oct 31, 2020
Colin42's Avatar
Re: How to disconnect horn & find repalcement?
You unplug it?
then cut the connector and crimp on like a blade terminal to connect it to the aftermarket horn
Old Nov 3, 2020
Vepy's Avatar
Noobie
Originally Posted by Colin42
You unplug it?
I couldn't figure out how to unplug it and didn't want to accidentally rip it. Is there a pin or something to pinch in somewhere before pulling off?
Old Nov 3, 2020
Colin42's Avatar
The little lock tab is on the back, you can kind of see it in the second photo, unbolt it if you want better access
Old Nov 21, 2020
Vepy's Avatar
Noobie
Would I be able to have two horns? I've been looking at these ones here:
Amazon Amazon
Or would I have to get a single horn similar to the OEM one? I've also been looking at horns from RockAuto, and they have ones just like the OEM ones that I would just buy.
Old Nov 22, 2020
If you had issues with removing the bolt in the picture... I would say stay with one horn, unless the dual horn is single wire input
thetexan
Oct 23, 2017 12:45 AM
ardaraciviclad
Sep 22, 2011 09:48 PM
Forum Bot
Electronics DIY
May 17, 2004 06:24 PM
astr033
Jun 5, 2003 07:02 AM
LuvDatCivic
Sep 27, 2002 01:16 PM
