General 6th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
HELP! Seized engine ?
Old Apr 26, 2018
Lilslamdcivic's Avatar
Lilslamdcivic is an unknown quantity at this point
Car will not start. No crank no start. Drove it to the store one day ,hopped back in it and it wouldnt start. Jist clicks. Checked battery and starter . Grounds. Fuses etc. no luck . Even tried push starting it to see it would even just start up. Nothing... when trying to push start it ,car just comes to a complete stop when letting go of the clutch.also tried to turn the engine from the crank pully to see if it turned. Nope... Would anyone happen to know what the problem is?? Engine seized?
Old Apr 26, 2018
Re: HELP! Seized engine ?
take to a shop...
Old Apr 27, 2018
Wankenstein's Avatar
Did you remove all the spark plugs first when you tried to manually crank it? If not, try that first.
Seized engine possible causes:
1) Running engine with oil too low
2) Long term head gasket breach at a location (of the head gasket) that allowed coolant to get inside of cylinder(s).
3) If you're using a long cold air intake it's possible it sucked up puddle or rain water and caused hydro-lock.
Possible fix:
Read this: ttps://www.jalopyjournal.com/forum/threads/how-do-you-unseize-an-engine.157517/
If it's definitely seized:
* Remove all spark plugs
* Pour a half cup of Marvel Mystery Oil in each cylinder through the spark plug holes and cover holes with a dry rag.
* Wait 24 hours or more and try to manually crank with all the spark plugs removed.
* If it turns over by hand then find a way (suction) to remove as much of the MMO as possible from the cylinders before running engine.
Your engine is an interference engine so ensure you spin the crank in the correct (counter-clockwise) direction:
civicsrcool
Apr 26, 2018 08:52 PM
superd21007
18
Mar 30, 2011 02:10 AM
ksteak
Oct 15, 2008 06:11 PM
NoSpleeny
Nov 7, 2005 06:22 PM
ELaudio
Dec 6, 2004 09:34 PM
