HELP! Engine seized!
Old Oct 15, 2008
ksteak's Avatar
ksteak is an unknown quantity at this point
Replaced my spark plugs and distributor cap/rotor today in my 97 Civic. To be able to get to the rotor, I pulled the entire distributor off the camshaft which allowed the rotor to turn freely to access the screw. I swapped out the new rotor. There's only one position where it will correctly line up with the camshaft again, so I turned the rotor against the camshaft until it popped into place. Reassembled everything.
When I first removed the distributor from the camshaft, a little oil came out of the camshaft opening (maybe a couple tablespoons worth). Is that normal? I added a little oil to compensate.
I also sprayed a buttload of B12 ChemTool T-body cleaner into the T-body.
I know that the B12 will make it hard to start... but the motor is basically seizing when I try to start it. It just locks solid into place and won't turn at all. I pumped the gas a little (assuming engine has some of that B12 cleaner in it)... it nearly turned over once, but keeps on seizing. I didn't want to keep doing it before consulting someone.
Can anyone help??!!
Old Oct 15, 2008
ksteak's Avatar
Re: HELP! Engine seized!
Oh and if I turn the key to the "on" position, my oil pressure warning light is staying on... others (ABS, etc..) turn off....
Old Oct 15, 2008
talin92071's Avatar
talin92071 is an unknown quantity at this point
did you sray the b12 into your t body if did it might have messed up one of the sensors
Old Oct 15, 2008
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
the oil pressure light will stay on until the motor is running and builds oil pressure. the only thing i can think of is you somehow managed to spray enough chemtool to hydrolock the motor. by the way, use an actual tb cleaner next time. anyway, pull the plugs back out and see if the motor will turn over without the plugs in. if it turns over, keep spinning it until it blows all the chemtool out and reinstall the plugs and see if it will start
Old Oct 15, 2008
ksteak's Avatar
Sweet! I let it sit for an hour -- went back out and, while it took forever to actually start, it's not locking up. Got it started and worked the cleaner through the system. Now resetting ECU... should be G2G.
THANKS!
Old Oct 15, 2008
the chemtool probably leaked past the piston rings so it would turn over. id change the oil asap
Old Oct 15, 2008
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
O_O Id have to see this bad boy and take it apart to see it. Kinda hard to answer this Hopefully someones had this problem before and knows what to do.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
juror
May 26, 2015 06:35 PM
SoCalChris
Jan 19, 2002 07:41 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
