General 1st - 5th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
D17A2 Swap into 1990 HB
Old Apr 6, 2022
Csimp5891's Avatar
Csimp5891 is an unknown quantity at this point
I'm looking for any info about swapping a D17A2 from a 03 civic into my 1990 Civic HB Standard if anyone can help me. What would it take to do. Any and all info would be greatly appreciated. Thank you.
Old Apr 6, 2022
Re: D17A2 Swap into 1990 HB
it does not have a dizzy nor a place where you can bolt it in.
ECU and sensors will be the biggest items you need to consider and ends up expensive. more than the engine
if you choose to use the 03 ECU, it will start looking for the chipped car key and more headaches ensue
Old Apr 6, 2022
Colin42's Avatar
For the amount of time, effort, and money that engine really isn't worth it. Look into b and k swaps
Old Apr 6, 2022
yeah, at the least the K have ECU options (albeit expensive anyway)
Old Apr 6, 2022
FRSam's Avatar
Click Here
If you want a cheap swap, look into some of the older D-series engines. Basically every D15 or D16 drops right into it, and are very respectable powerplants. The D17 is an absolute pain comparatively.
Paul Brewer
non-VTEC to VTEC Head swap
Mar 3, 2021 06:42 AM
Blake Kelly
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Jul 5, 2019 11:06 AM
Greg DePrima
May 26, 2017 03:50 PM
reezy71
Apr 23, 2006 02:28 PM
Civicman1988
Aug 2, 2005 12:26 PM
