General 1st - 5th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Buying a 5th gen EX trim.
Old May 13, 2021
wheatroot's Avatar
wheatroot is an unknown quantity at this point
So I've been thinking about buying a 5th gen Civic sedan, should I try to wait out an EX trim for the improved D16 engine, or is it not even worth my time to wait for one. Being new to the market I'm unsure about availability between the trims so I was looking for some general insight into which trims are most available, I don't really want a DX trim but if that is really the only thing available I will go for it and ignore waiting on LX or EX trims. Any help is appreciated, thanks.
Old May 13, 2021
FRSam's Avatar
Click Here
Re: Buying a 5th gen EX trim.
It depends on if you're getting a manual or not. If you are, wait for an EX. If not, don't waste your time. That's my thought process on it, anyway.
Old May 13, 2021
also, getting pretty difficult to find stock cars by now. You will need to check engine code to know if they were swapped or not
Old May 14, 2021
Wankenstein's Avatar
Live in Florida? I'm thinking of selling my '95 EX (swapped engine B20).
Old May 16, 2021
wheatroot's Avatar
Depends on how much we are looking at, I'm in NC but me and my dad could drive down if it's a good deal.
Old May 16, 2021
I live in NC also in the Piedmont triad area. My son and I are driving the car from Florida to NC in late June. I will garage the car here and he is moving from FL to NYC.
Due to the modded engine I don't think it will pass safety inspection in NC. It's age doesn't require emissions testing.
Price is $3,500 firm. 95' EX Coupes are going up in value as they are getting harder to find. Mine is in very good condition and no mechanical issues.
Old May 16, 2021
Here it is: https://www.civicforums.com/g/album/8160578
Old May 16, 2021
wheatroot's Avatar
I would DEFINITELY be interested, and 3500 is an amazing price, do you have a phone number, my name is Evan.
Old May 16, 2021
I wouldn't sell you a car that won't pass state (NC) inspection if you intend it to be a daily driver. My wife and I moved to NC about 18 months ago and prior to moving here I called a few shops here to find out if my car can pass, I told them it has a swapped engine and they all said it won't pass as it has to be the same engine code as what came out of the factory (1.5L).
Unless, you are going to use it as a track car only you probably can't register it in NC. Florida doesn't have inspections so the car sat at my mom's house unused for over a year until my son moved from California to Florida. I gifted the car to him. Now, he's moving out of Florida and it won't pass NY state inspection either.
Old May 16, 2021
wheatroot's Avatar
How do they decide what engine is in it, isn't the b series pretty similar to d series in terms of looks, do they come look at it personally or is it more of a you get caught and the car is impounded, because this would be my daily.
-edit I'm doing some googling and it seems like it just has to meet emissions, be the same brand, and be the same year or newer engine, I know you called some shops but I'm unsure about what to trust.
-edit 2 (from the EPA) "It should be noted that while EPA's policy allows engine switches as long as the resulting vehicle matches exactly to any certified configuration of the same or newer model year as the chassis"
Later civics have B20's in them, wouldn't this then make it legal.
Old May 16, 2021
FRSam's Avatar
Click Here
One is DOHC, the other is SOHC. Massive visual difference.
No civics ever came with B20's. B20's came in CR-V's, which I suspect are worse for emissions that civics.
Old May 16, 2021
wheatroot's Avatar
Ah, where they in any subdivisions of the civic, del sol, cr-x, prelude etc, also, would a couple teenagers at Jiffy Lube really see that it wouldn't pass, I mean, this is a deal I'm not really sure I want to pass up, just because I haven't found anything relatively close to even driveable yet, and the luck with you being in the Piedmont region, I'm just trying to find any solution.
Old May 16, 2021
FRSam's Avatar
Click Here
I'm not the guy with the car. That's HR.
B20's came only in the CR-V and first gen prelude (which would fail anyway because it's an OBD0 engine). If the car was able to pass, it doesn't sound like he'd be selling it.
Old May 16, 2021
OP...Chez is correct.
I can't consciously sell you a car that you won't be able to register.
Old May 17, 2021
wheatroot's Avatar
Disappointing, I thought I found myself a car, thanks for the offer anyways. Do you have the original D16 for the car though?
-edit Also I appreciate the honesty, you could have dumped it on me and left me screwed.
Old May 17, 2021
Prior owner did the swap and he bought as a shell (no engine) from his friend. It was an automatic transmission orginal and he swapped in an Acura LS manual.
BrotatoChip
General 7th Gen
Aug 14, 2018 04:00 PM
jeffsta17
May 21, 2006 08:59 AM
Hardhittinz
Dec 7, 2003 09:55 PM
MrDisco99
Jun 12, 2003 04:44 PM
CivicRiderCA
May 23, 2002 11:05 AM
