General 8th & 9th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
Jack
Old Jan 4, 2019
Meanie's Avatar
Meanie is an unknown quantity at this point
Jack
I just realized the other day my 2014 civic EX coupe is missing the stock jack. I did a search on Ebay and noticed the older model jacks are much cheaper than the newer models but they look the same. Therefore, can anyone tell me if they are the same and could I use an older model jack?
Thanks
Old Jan 5, 2019
Colin42's Avatar
Re: Jack
Probably, as long as it's the same generation it will be the same. Or hit the junkyard and get one for like $5
Old Jan 5, 2019
Re: Jack
or get a scissor type in any autoparts store. the knee type scares me...
Old Jan 5, 2019
Colin42's Avatar
Re: Jack
I hate scissor jacks with a passion, much prefer hydraulic ones
Old Jan 5, 2019
Meanie's Avatar
Re: Jack
That's what I meant regarding Ebay. The older generation jacks are cheaper while the newer ones are more expensive. Thus, the question again is are the older generation jacks the same as the newer generation?
Old Jan 5, 2019
Meanie's Avatar
Re: Jack
Scissors are fine in a pinch and I want it to fit in the Styrofoam insert in the trunk.
Old Jan 5, 2019
GolNat's Avatar
Prelude Owner
Re: Jack
A jack is a jack. As long as it’s rated for the correct #’s I don’t see a problem with using an older one.
I have a scissor style one with tools for a Honda Fit lying around. I can look at the rating on it.
Old Jan 6, 2019
Meanie's Avatar
Re: Jack
Agreed, I am just wondering if the top slot would differ. Some jacks have a little divot/indent while others have an actual slot. My generation has the slot like this..
Instead of an indent like this...
I know I'm probably making a mountain out of a molehill. Sometimes I'm just a stickler for actual OEM item for my car.
Old Jan 6, 2019
Colin42's Avatar
Re: Jack
Exactly they're fine in a pinch, I'm only going to use one if I get a flat in my car
Old Jan 6, 2019
Meanie's Avatar
Re: Jack
Which is the only reason I want to keep one in my trunk.
I recently had new tires installed. Prior to that, I had slow leaks and an abundant of objects embedding into them. It made me think of the possibility of being stranded without the tools to install my spare. Thus, the reason for my question. I may just take the advice of a junkyard, older generation jack on Ebay or Harbor Freight. I have to get over this OEM mindset and realize it's just a jack.
That's the fact, Jack!
Old Jan 6, 2019
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
Re: Jack
meanie even if You hit the Junkyard im prety sure even a 8th Gen Jack should fit & work perfect i dont think Honda has changed any of there Jack designes since i have owned One on a Previously older Car being since 1986.
Old Jan 6, 2019
Colin42's Avatar
Re: Jack
That's why I said junkyard, it's the cheapest option and you will most likely end up with the correct OEM jack
ImportRacer2123
Sep 7, 2005 09:27 PM
Hawk
Apr 27, 2002 09:29 PM
FlexEX
Apr 16, 2002 10:29 PM
